Old 11-17-2017, 04:19 PM   #101
GAc10boy
GAc10boy's Avatar
Re: 1968 GMC Shorty - Pearl
Yesssuh! Steelies and caps for the win!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 11-17-2017, 06:44 PM   #102
Graham57a
Graham57a's Avatar
One step closer. The color looks a little closer after the paint finished curing.
Graham57a is offline   Reply With Quote
Old 11-17-2017, 07:52 PM   #103
Kronald_70GMC
Kronald_70GMC's Avatar
What a cool truck! Love that you are keeping the patina!
Subscribed
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 11-19-2017, 09:00 PM   #104
Graham57a
Graham57a's Avatar
Spent some time today on the pass side inner rocker.
Old 11-19-2017, 09:06 PM   #105
Graham57a
Graham57a's Avatar
After it was tacked into place I was able to test fit the outer rocker to check my door gap. I was pretty happy with everything but I didn't like the way it line up with the cab corner. You can see the factory spot welds held the cab corner about 1/4" lower then the bottom of the inner rocker so the only way to fix it was to move the cab corner
Old 11-19-2017, 09:11 PM   #106
Graham57a
Graham57a's Avatar
Once I figured out that I could make everything work I finished welding the inner into place
Old 11-19-2017, 09:15 PM   #107
Graham57a
Graham57a's Avatar
With the inner done I moved onto the cab corner. My hope was to move the existing sheet metal but once I shaped it I discovered a few thin spots where the rust was about to eat through. So I cut it out and patched it
Old 11-19-2017, 09:22 PM   #108
Graham57a
Graham57a's Avatar
Finally I excessively applied por-15 to all bare metal spots that won't be exposed when I'm finished. Should help this thing stay solid for another 50 years
Old 11-19-2017, 10:53 PM   #109
GAc10boy
GAc10boy's Avatar
Really excellent work.
- Robbie
Old 11-22-2017, 08:58 PM   #110
Graham57a
Graham57a's Avatar
Painted the inside of the rocker and the inner rocker and bare metal on the floor board tonight. Then double checked my fit and plug welded the outer on
Old 11-22-2017, 09:00 PM   #111
Graham57a
Graham57a's Avatar
Finally paint matched the cab corner. You can see how much better the bottom aligns now
Old 11-22-2017, 09:00 PM   #112
Kronald_70GMC
Looking good man! Im itching to get going on my cab.
Kyle
IG: kyle_ronald
Old 11-22-2017, 09:42 PM   #113
68bowtie
68bowtie's Avatar
That looks fantastic. Grandpa gets a makeover.
Old 11-23-2017, 07:52 AM   #114
hewittca
hewittca's Avatar
The wheels/tires look so good! And nice job on the cab corner, the paint match looks perfect. What paint did you use?
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 11-26-2017, 08:22 PM   #115
Graham57a
Graham57a's Avatar
Thanks man
Haha yes sir!
Thanks man, right now I'm using a rattle can paint match from automotive touch up but in person the color is off just a shade or two so I plan on having a local paint shop scan the bottom of one of the fenders and mixing up some single stage.
Old 11-26-2017, 08:29 PM   #116
Graham57a
Graham57a's Avatar
Got a ton done this weekend. Got my RF fender done, cut out the bad metal, cleaned everything really well, used por-15 to seal the rusty metal, and patched the metal back. Also got the bottom of the pass door cut out, all the guts removed, soaked in phosphoric acid, and I'll hopefully patch back in the next day or so. I got the kick panel patch done (forgot to take pics), and a small floor patch on the pass side. Once I get the pass door done I'll be finished with rust repair on the passenger side.
Old 11-26-2017, 08:40 PM   #117
Graham57a
Graham57a's Avatar
RF fender cup. I ended up using the entire back structural section of the patch panel but left about 2-3" of outer og paint below the top of the inner structure. I had to bust a few spot welds but it was definitely worth it, I think it turned out decent. It'll need a skim coat of filler but should do the trick
Old 11-26-2017, 08:44 PM   #118
Graham57a
Graham57a's Avatar
Pass door before and after the cut
Old 11-26-2017, 08:48 PM   #119
Graham57a
Graham57a's Avatar
A couple of the interior of the door. I thought it was kinda cool finding the runs in the factory inner coating, it looks like the inner coating was applied with the door on its side
Old 11-26-2017, 08:57 PM   #120
Graham57a
Graham57a's Avatar
Got my patch panel cut out of the donor tailgate and decided to hang it on the wall, also got a ton of smalls cleaned up and stored away for final assembly. Before and after on the LF fender trim. It's not perfect but neither is the rest of the truck
Old 11-26-2017, 09:07 PM   #121
Graham57a
Graham57a's Avatar
Cleaned the instrument cluster and painter the needles. Once I repaint the bezel I'll be able to assemble the cluster for the last time (hopefully). I used scotch brite to clean the copper on the printed circuit and dielectric grease on all grounds and connectors.
I also started experimenting with different waxes, polishes, and compounds to see what gave the paint the best shine. I think we will end up using a Meguiars polishing compound and a carnuba wax to finish
Old 11-26-2017, 09:10 PM   #122
Graham57a
Graham57a's Avatar
Finally a little mock up of the fender and door after a little paint match and wax. I forgot to take a pic of the fender after paint so this is the best we got
Old 11-26-2017, 09:47 PM   #123
cericd
cericd's Avatar
Lookin' SHARP!
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 11-28-2017, 05:44 PM   #124
Graham57a
Graham57a's Avatar
Not a ton of progress but I did get out the paintbrush and lay down some por last night. Should be able to fit the door bottom in the next couple days and hopefully weld it in this weekend
Old 11-28-2017, 11:06 PM   #125
GAc10boy
GAc10boy's Avatar
man, you're killing this! Nice work.
- Robbie
