Old 11-20-2017, 02:54 PM   #1
clemsonteg
Tensioner causing squeak?
Is there a way to determine if the squeak I am experiencing is coming from my tensioner? I have a 5.3 with a kwik performance ac bracket and z28 tensioner as described in their instructions and I have a squeak that begins around 1500 rpm. I put a wrench on the tensioner and gently applied pressure and the squeak goes away. The tensioner only has a few thousand miles on it.
clemsonteg is offline   Reply With Quote
Old 11-20-2017, 05:23 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Tensioner causing squeak?
the LS1 tensioners are well known for this squeak. the only real remedy is to replace the tensioner pulley
Willie Makeit is online now   Reply With Quote
Old 11-20-2017, 06:14 PM   #3
LeesTruk
Couple of things to try;
spray some water on the belt at the described rpm's. If it's a belt noise, it'll go away briefly then come back
using a long probe of some kind (screw driver, dowel, even a length of hose, etc.) put one end on the tensioner, the other to your ear. A squealing bearing will become very evident. This can be applied to any belt driven device to check for noise
LeesTruk is offline   Reply With Quote
Old 11-20-2017, 06:28 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Pretty much every LS truck I've worked on has pulley squeak somewhere. I notice it most on cold start high idle. Once your truck is loud enough, you don't notice it anymore lol.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-20-2017, 10:10 PM   #5
clemsonteg
Replace it with a stock replacement or larger for more belt contact and reduced chance of slip? The ac bracket came with a smooth pulley because of how the belt routes.
Old 11-20-2017, 10:12 PM   #6
clemsonteg
I'll try the water trick. Since the noise goes away with added tension, will the water cause it to slip or grip?
Old 11-21-2017, 05:49 AM   #7
LeesTruk
The water just acts as a lubricant, and it'll tell you if your belt is hard/brittle, or dry. It just separates a "belt" noise from a mechanical one
Old 11-21-2017, 11:57 AM   #8
clemsonteg
Water definitely makes the noise go away and so does adding tension.
Old 11-21-2017, 11:57 AM   #9
Willie Makeit
not sure it matters as the squeak is in the bearings, not the belt - that's been my experience
I have gone as far as taking the dust covers off the bearings, cleaning and repacking with fresh grease, only to have the squeak come back within a month or so.
Old 11-21-2017, 12:17 PM   #10
clemsonteg
I swapped to another belt I had and shimmed one pulley. It's gone for now, but I think last time I messed with it I had a few weeks of silence before it returned. I took a photo of the tensioner, which marks am I supposed to be watching?
Old 11-23-2017, 12:46 AM   #11
jweb
jweb's Avatar
I had the same problem, I switched to a Goodyear Gatorback belt and the noise hasn’t come back.
jweb is offline   Reply With Quote
Old 11-25-2017, 01:02 AM   #12
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
If the dive isn't aligned, it will squeak.. and in the picture, the mark it's on means the tension is just right. Now the belt looks like it's riding on the tensioner pulley edge. If you can center the belt on that tensioner you might get rid of the squeak if that's the source.. have you called the manufacturer? If not, you should so you get a direct answer on your problem.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
