11-20-2017, 09:17 PM | #1 |
brake line tabs
Does anyone else have the brake line tabs welded to the front on the front cross-member. I am thinking someone had done this for whatever reason. The new 11.5 inch lines I have for replacements are to short since lower the front 4.5 inches. Anyone out there know of a replacement brake line to use. Do not really want to relocate the tabs as everything in now painted and finished
11-20-2017, 09:57 PM | #2 |
Re: brake line tabs
I believe you have a 71 or 72 cross member. The factory brake lines run on the front side of the cross member of those years from the factory. Do a search and I am sure you will be rewarded with the part number of a longer hose that works on a lowered truck.
Good luck
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-20-2017, 09:57 PM | #3 |
Re: brake line tabs
I believe I used 1973-1987 one ton brake hoses. They are about about 3 inches longer.
Scott |
11-20-2017, 10:02 PM | #4 |
Re: brake line tabs
Thank you both for the quick replies, will check with the parts stores in the morning.
Jack |
11-20-2017, 10:07 PM | #5 |
Re: brake line tabs
Pappy you can use the 71-72 3/4 ton or 1 ton brake hoses also, they are a inch longer. I liked the 73-87 hoses because they're considerably longer.
Scott |
