#126 |
Happy to be here
![]() Join Date: Mar 2000
Re: Elwood the 77_remix
You will need to contact your local Wheel Pro dealer. They can give you info on pricing and availability.
#127 |
Happy to be here
Friday night shop session was focused on the rear axle. I wanted to pull it to clean it up a bit. The stock shock mounts were still attached, and the pinion seal is seeping.
I had preciously removed most of the 4 link and set it aside. I finished removing some components and disconnected the E brake cable and brake line. I pulled the inspection cover and drained the gear oil. While that was off, I tested the fit of the Moser Engineering differential cover. I was concerned that the panhard bar mount might create a conflict, and it does. I'll address that issue later.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-18-2017 at 12:18 PM. |
#128 |
Happy to be here
With the 12 bolt on the ground i was able to slide it out from under the truck. I recall removing the bottom shock mounts from Scarlett while laying on my back. I decided to do it standing up on Elwood.
After a few minutes with a cut off wheel, followed by a flapper disc the axle was cleaner looking. I plan to make new brake lines and replace the rubber with braided stainless. I am working with Wilwood to determine what brakes I will run. That will decide how the lines are laid out. Time constraints wont allow me to change gears and add a locker. My 3.08 one wheel peel differential will have to do for now.
#129 |
![]() Join Date: Feb 2011
Hooked & reeled in Ken! Elwood is spot on in so many ways
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#130 |
Happy to be here
Come on in and enjoy the show.
#131 |
Happy to be here
I finally had a few minutes to compare the specs on the mufflers I was considering. I am restricted by my RideTech 4 link not allowing space to run a true dual system out the back. Consequently I need a free flowing muffler that wont be too loud in the cab.
I looked hard at the Borla XL series since I have them on Scarlett and know what they sound like. I compared them to the Magnaflow for size, appearance, and sound. Its hard to compare sound when there are so many variables, but I listened to several sound clips and liked the Magnaflow stainless series best. The end result is I will be running a MagnaFlow 14336 which is a 2.5" SI/SO. Up front I have 2.5" Corvette ramhorns flowing in to a mandrel bend Y pipe. I will use Deeds Engineering V bands to connect to a Vibrant Performance #64810 10" flex coupling going back to the Magnaflow muffler. That will be suspended by Deeds Engineering billet brackets and hangers. From there I will have to rely on Alex my exhaust technician at New Star Muffler to work his magic and get the exhaust pip under the rise in the frame to the wheel well.
#132 |
I believe that will be a great choice!
85 Silverado - 350/700r4 |
#133 |
DeJaVu for me with my last weekend!....I fitted up my 4 link conversion
I also will have to modify my moser cover....thinking of just welding together.....or even welded bracket to actual diff housing instead... Last edited by N2TRUX; 11-22-2017 at 11:51 AM. |
#134 |
A guy with a truck
I like my stainless magnaflows, but with the small block, they can get a little glass-packy. Brrraaaap!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#135 |
Happy to be here
I hope it has a good sound. I'm going to run as much tailpipe as possible to clean it up.
#136 |
Happy to be here
I wont be able to determine a solution until I get the axle back in place. I need to see how much needs to be removed from the bracket, or housing. I dont want to compromise the integrity of either part.
#137 |
Happy to be here
I received a batch of goodies from Deeds Engineering yesterday. I would normally say the pics dont do them justice. In this case Kevin has some fantastic photos on his website and the finished product looks just as nice. These definitely are multi level up in quality over standard exhaust components.
#138 |
Wow those are nice. Trying to picture how they bolt up.
#139 |
Happy to be here
The V bands are a three piece component. There are two rings that slide over the exhaust pipe. The outer band clamps around both rings and clamps them together to create a seal.
Those flat tabs are weld to the exhaust system. The "dogbones" are captured between the tabs. They have a built in bushing to absorb some of the vibration. There are additional hangers that will be utilized as we get the system laid out.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-22-2017 at 11:52 AM. |
#140 |
Very cool.
#141 |
Happy to be here
A swing, and a miss. I got my exhaust parts from Summit today. I wanted to test fit everything to see how it fit. Yikes! I was not even close. In my defense, its not easy trying to lay on your back, hold parts in place, and measure what you need.
I ordered a 10" Flex fitting and its way too long. I wanted as much flex as possible but a 6" tube will have to suffice. I mistakenly pulled the Magnaflow part number for a offset/offset muffler. Instead I need a center/offset to work. Fortunately Summit has an excellent return policy. Since the parts weren't installed, they emailed me a prepaid return label. As soon as they see that I shipped the parts they will process my new parts. Thanks Summit!
#142 | |
Happy to be here
I was sick over the Thanksgiving weekend so i didnt get any shop time. I manged to finish my work on Friday but that was about it. Saturday was bad and Sunday I slept all day. I'm somewhat better today, so I'll be doing updates later.
#143 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Everything looks fantastic as usual! Can’t wait to see that interior finished up!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#144 |
Happy to be here
It really sucked not being able to put in shop time this weekend. I'm trying to shake a respiratory infection and I find the best cure is sleep. Consequently I was rather depressed today after a much needed weekend past by.
Fortunately I received some pics today from Brent at Sculpt Garage He is almost finished with the seat for Elwood. I wanted to wait till I picked it up to post pics, but I cant. I'm really pleased with the results. The insert material is OEM for earlier squares, and the red emulates the 1977 grain. Its a brighter red by Enduratex in the Oxen series. Its a bit brighter than what I wanted but so far everyone I show it to likes it better than my choice. Lets see what the critics think?
#145 |
Spot on! Beautiful
#146 |
Looks really good!
#147 |
Where did you source the OEM material?
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
#148 |
![]() Join Date: Dec 2006
That's next level stuff for sure. Ken, yourself and Elwood is what has inspired a lot of us younger guys to get into the squarebody trucks. This definitely raises that bar to another level. Killer work as usual sir.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
#149 |
I'm just glad to be here!
The new seat looks great! I really do like the red you used!
Can't wait to see Elwood in February.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#150 | |
Happy to be here
