Old 11-21-2017, 10:38 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Do you have OEM CA emissions / smog equipment still in place?
Just curious who has CA emissions equipment still on their motor. I'm trying to reconstruct the missing system on my current Blazer build. My other blazer has its original equipment still intact.
Let's see some photos documenting the CA emissions systems.
Old 11-21-2017, 10:44 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Do you have OEM CA emissions / smog equipment still in place?
My truck has the Federal emissions package, so I can't take pictures to help you. However, if you need to see what was used, the Chassis Service Manual has pictures and schematic diagrams of the systems used, to help you. Someone here was gracious enough to scan in the entire manuals for a number of years; you should be able to find what you may need from those manuals.
~Steven
Simi Valley, CA
Old 11-21-2017, 10:45 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Slowly coming together on the blue blazer.
Old 11-21-2017, 10:49 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you! The manual had an example from 68 - some brackets differed. I couldn't find a schematic for 72. It helps having the other blazer to reference. I'm curious how these systems differed over the years and for AC vs non-AC trucks and what problems if any others have with their systems. Granted many or most systems were probably tossed out long ago.
Old 11-21-2017, 11:34 PM   #5
davischevy
davischevy's Avatar
I can take more if you need them. I guess I should have called and let you look at it early that morning when I came back through Albuquerque.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-21-2017, 11:36 PM   #6
davischevy
davischevy's Avatar
BTW, mine has what sounds like an exhaust leak. I had new exhaust installed, but the noise is still there. Do you have any ideas.
other Larry
Old 11-22-2017, 12:07 PM   #7
Coley
Coley's Avatar
Smile Re: Do you have OEM CA emissions / smog equipment still in place?
Check the back of the emissions unit for a vacuum port.
It looks like the vacuum line from the (california/emissions) carb has been plugged (in your 1st pic) and I believe this normally runs to the emissions unit.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 11-22-2017, 05:34 PM   #8
davischevy
davischevy's Avatar
Coley
Thanks, I'll check it out.
other Larry
Old 11-22-2017, 11:26 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I've read the pump can seize over time and makes a racket but wouldn't suspect that would sound like an exhaust leak. If the diverter valve diaphragm fails it can produce a vacuum leak (read it can be cured by placing a BB in the signal hose to the valve) and continuously dump air into the exhaust manifolds that can cause back firing.
I found a guy who rebuilds divertor valves for the corvette crowd. Rock auto recently had a close out on some USA made reproduction diverter valves for like $10. These are plastic and the hose tubes oriented differently but I may use one until I can have the original unit rebuilt.
Next time Larry! Thanks for the pics!
Old 11-22-2017, 11:28 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's an AIR schematic for a small block - generic and not specific for a pickup though.
Old 11-22-2017, 11:32 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I've been able to scrounge some NOS pieces to rebuild the system in my Blazer.
Old 11-22-2017, 11:33 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
....even a pump.
Old 11-22-2017, 11:36 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The emissions decal for CA emissions half tons in 72 made use of this LM decal (not reproduced to my knowledge).
Old 11-24-2017, 11:03 AM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Example pic of AIR brackets and AC brackets for SBC 1972
Old 11-26-2017, 03:55 PM   #15
toms68cst
toms68cst's Avatar
I have a complete AIR System on my 68 if you need any more info/pictures. As I recall, at least in 68 only the standard transmission - half tons had AIR systems. There were probably different rules in later years.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 11-26-2017, 05:35 PM   #16
tdangle
tdangle's Avatar
Guess I am lucky. My 3/4 ton 1970 had no emission controls, outside of the spark and fuel calibrations. Good luck getting it all together, so many people removed all that stuff years ago.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-29-2017, 01:15 AM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm really curious about 68 actually because I've seen two half ton 4wd trucks both seemed to have AIR brackets but CA emissions not listed on the SPID. Did all standard tranny V8 trucks in 68 have AIR equipment?
Old 11-29-2017, 01:17 AM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks. I've been able to scrounge the parts but need to have the diverter valve rebuilt.
No 3/4t trucks had AIR - I believe these were emissions exempt.
Old 11-29-2017, 09:23 AM   #19
57taskforce
All about them K’s
57taskforce's Avatar
Looking good Pete!
Tyler
Old 11-29-2017, 01:14 PM   #20
davischevy
davischevy's Avatar
I can't speak to the 1968 V8 trucks, but my dad bought a new 68 1/2 ton, six cylinder, TOT, and it had an emissions system. I don't know where the truck was built, but not likely in California.
He traded it in on a new 69, 350 engine, 350 automatic, and it did not have an emissions system.
other Larry
Old 11-29-2017, 10:01 PM   #21
toms68cst
toms68cst's Avatar
From what I've seen, The AIR Pump (In 68 anyway) was installed nationwide (Not just Calf) on 1/2 ton - manual transmission trucks. I don't think it made a difference if it was a 6 or V8. I think the automatics had heat risers. My truck has no smog option listed on the glovebox. I am pretty sure it was purchased in the midwest.
3/4 ton trucks and heavier seem to have had fewer smog control requirements in 68.
Old 11-30-2017, 03:25 PM   #22
Bigdav160
Bigdav160's Avatar
Here's the tag from my '72 California 3/4 ton 4x4 Suburban. I have no reason to suspect the fender well has been replaced. The engine has been replaced along with the exhaust. PO installed headers/aluminum intake. No AIR brackets left.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-30-2017, 05:13 PM   #23
Coley
Coley's Avatar
My truck was a California truck for most of its life and came with all the emissions stuff (pump, brackets, hoses, connections, pipes, etc) when I got it.
That stuff was all removed and off within a couple of hours once I got the truck back to B.C.....and now all in a box under the bench in the shop...probably never to see the light of day again, lol.
Coley
2000 Dodge Ram 1500
Old 11-30-2017, 06:38 PM   #24
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That's helpful info. Thanks for sharing.
Can you post a pic of the SPID listing the CA emissions equipment? 3/4t emissions decals were different than 1/2t in 72. That you've listed is for a 1/2t application. 3/4t emission decals were located on the radiator support.
Coley
Make space in the garage - give me the box
Old 11-30-2017, 06:39 PM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by 57taskforce View Post
Looking good Pete!
Thanks! Shoot me a text when possible - lost all my phone data
