Old 11-24-2017, 03:41 PM   #8
vin63
It's Better With Nitro
vin63's Avatar
Re: Source for Carpet?
Yes, ACC kit from Stock Interiors. The back panel carpet piece works well, but I would recommend using additional industrial strength velcro in the low spots. Let it set in the sun for awhile before installing it to get the carpet to relax a little so it will form around the corrugated pattern (same as I did for the main carpet piece) a bit easier.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
carpet
