Will 700r4 need a high hump?
My cab is at the body shop and before its painted I wanted to find out if I need a high hump tunnel for a 700r4 trans. Truck is a 69 with a 400 SBC. I have researched this topic and have seen both yes and no answers. Brother's sells a nice steel replacement unit.
![]() Join Date: Jul 2016
Re: Will 700r4 need a high hump?
No it will not need a high hump.
In fact a big block and TH400 will fit a low hump with decent clearance. I've had multiple trucks with the 700 and low hump. |
Old member
x2.
I had my 305TPI with 700-R4 no problems. I now have 6.0 with 4L80E no problems. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I am glad to know this as I am preparing to install a 700 r4 in my truck and was wondering if I needed to change the hump.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
![]() Join Date: Feb 2004
Agree that a high hump is not necessary but on my 67 --- bbc even moved forward an inch -- I did have to slightly massage the passender side just below the cover for the 2-4 servo cover. May not be necessary on yours and is no biggie.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
Thank you guys. Exactly the information I was looking for. Love this forum!
![]() Join Date: Mar 2003
I've got a 69 with a big block--T400 trans and a low hump, fits fine. I can get my hand around it
