Old 11-27-2017, 12:56 PM   #1
Captain J
Exclamation 1972 GMC Sierra c2500, electric
Hi, 2 issues
One, when I drive for an hour or so, and I turn off the truck, it won’t start, starter is slowly turning like with a low voltage battery, but when I leave the truck to cool, it will start again. Any thoughts.
2ed, this wire runs on the front grill, from the left side to near the battery on right side, it’s disconnected near the battery has 2 small glass fuses.
What’s for?
Where it should be connected to?
Pictures attached,
1972 GMC Sierra C2500, V8-350
1986 GMC Sierra C2500, V8-454
1986 GMC Sierra C2500, V8-LS1
1986 GMC Sierra K2500, V8-350
1987 GMC Sierra R3500, V8-454
1997 GMC Sierra K2500, V8-454
Captain J is offline   Reply With Quote
Old 11-27-2017, 01:21 PM   #2
demian5
demian5's Avatar
Re: 1972 GMC Sierra c2500, electric
That is for you your ammeter only. I do not believe it would have any effect on your starting.
Check all of your grounds on the motor, body, frame, make sure they are all clean and tight as well as your battery cables.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-27-2017, 01:31 PM   #3
Doug's68SS
my 68 started doing that, it has a 396 in it and the passenger exhaust manifold had a crack in the bottom that was heating up the starter. would start when it cooled off. I installed a heat shield until I got a manifold to replace it and then I left the heat shield in place.
Doug's68SS is offline   Reply With Quote
Old 11-27-2017, 01:34 PM   #4
Captain J
Demian5, thanks for your reply
Is it hooked to the battrey? Because when I tried it shorted out, blew a mini glass fuse.
I cleaned all my grounds, battrey cables, starter connections. I may put new battery, even though the battery is an Optima.
Old 11-27-2017, 01:36 PM   #5
Captain J
Doug’s68ss, thanks for the tip. mine has the heat shield, but I’ll recheck it,
Old 11-27-2017, 06:03 PM   #6
demian5
demian5's Avatar
You will need a DVOM to check for a short to ground somewhere in the circuit that is blowing your fuses (hence the reason it is already disconnected).
https://www.google.com/search?ei=WIs....0.52WKpa_kMwU
I believe it connects to the plastic junction block that attaches to the pass fender.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 11-27-2017, 11:17 PM   #7
allchevy58
allchevy58's Avatar
Battery may have a shorted cell, try jumping it when it does it again and if it starts, buy a new battery. Not sure about second issue, have to look at my truck. Believe that wire bolts to the fender on the battery side, grounded.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 11-28-2017, 09:41 AM   #8
Captain J
Allchevy58, I’ll buy new battery, and see.
Ok, thanks
Old 11-28-2017, 01:27 PM   #9
demian5
demian5's Avatar
Ok, thanks
You can have it tested for free. I had a red top optima last 10 years in my 64 impala.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 11-28-2017, 01:32 PM   #10
Captain J
Exclamation Re: 1972 GMC Sierra c2500, electric
You mean (the plastic junction block) the negative (ground) side? Or positive side?
Because I am confuse, if it needs a ground, why not ground it to the driver fender? Because when I tried to hook it to the positive junction, it shorted out blowing one of the tiny glass fuse.
Old 11-28-2017, 01:35 PM   #11
Captain J
We have no dealer for Optima, where I live, however I put a new battery and it cranked right away, which means the Optima battery is bad. But I still need to test the starter after a long drive, if the issue comes back.
I’ve 2 other Optima in my other trucks and they work great.
Old 11-28-2017, 02:37 PM   #12
demian5
demian5's Avatar
A battery load test is a battery load test, don't need a specific dealer for that.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 11-28-2017, 03:56 PM   #13
Captain J
Oh, ok. I misunderstood, sorry
Old 11-29-2017, 12:28 AM   #14
allchevy58
allchevy58's Avatar
Your wire should run to a positive block on right fender. You must have a short. Wire diagram shows it going to high beam switch and headlight switch. Looks like it tees off to alternator too. Someone spliced in the red wire to the black with the flat fuse.
Old 11-29-2017, 09:01 AM   #15
rockyrivermark
I had the same problem. It was heat soak in starter coming off the exhaust.
Put a heat shield on and problem solved.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 11-29-2017, 11:29 AM   #16
Captain J
Thumbs up Re: 1972 GMC Sierra c2500, electric
Thanks for the pictures, the headlight switch works ok, so is the the high beam, but I’ll recheck.
Old 11-29-2017, 11:30 AM   #17
Captain J
Mark
Old 12-03-2017, 02:06 PM   #18
Captain J
I did find the heat shield in my truck, can you pls send me a picture of yours or part number, and from where you bought yours? I truly appreciate it.
Old 12-03-2017, 03:14 PM   #19
Eddie H.
Eddie H.'s Avatar
This was a common problem with GM trucks in the 70's and 80's. It was caused by excessive exhaust heat. When I was working at a Chevy dealer , GM had a service bulletin that had us install a heat shield, along with a different solenoid and spring.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 12-03-2017, 04:14 PM   #20
Captain J
Do you know the heat shield part number, and where can I buy it from?
maybe a picture of the shield? Thanks
Old 12-03-2017, 06:07 PM   #21
Eddie H.
Eddie H.'s Avatar
I don't know the GM part number, but they are available from Jegs, Summit, Ebay, etc
https://www.ebay.com/itm/Satin-Alumi...RXsjrK&vxp=mtr
Old 12-05-2017, 03:58 PM   #22
Captain J
Thanks a lot
Old 12-05-2017, 10:23 PM   #23
RichardJ
The 4 Amp fuse should be connected to the Junction block at the battery. The wire goes through the firewall connector, directly to the Ammeter. A second wire from the Ammeter comes back out to the other 4 Amp fuse.
You could have a short anywhere on those wires or something shorting the back of the Ammeter.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 12-05-2017, 11:29 PM   #24
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Common sense tells me that a bad battery would start a vehicle good when it was cold, and then not start it when it was warmed up good , rather just the opposite. Heat soak is a common problem with headers or a manifold too close to the starter.
If the solenoid will not click then it is heat soaked, and if it clicks but the starter will not turn, then the starter windings are heat soaked. When electrical items get too hot then the wires will build up too much resistance for the voltage to overcome, and no current flows to operate the items.
If the solenoid is the culprit then here is a very good work around.
Get yourself a Ford solenoid and run the purple GM solenoid wire to it and run the battery positive cable as shown with a jumper from the large terminal on the GM solenoid to the S terminal where the purple wire was originally. The result is you get a full 12 volts to the GM solenoid and it will solve the heat soak issue in most cases. If the starter windings are heat soaked then a heat shield is the best cure less buying a brand new heavy duty starter.
Another benefit of the Ford solenoid is that it takes much less current to activate it, which is easier on the ignition switch for longer life.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-06-2017, 01:58 PM   #25
demian5
demian5's Avatar
Originally Posted by VetteVet View Post
Get yourself a Ford solenoid....
Only place where ford had a better idea...
1986 C20 Scottsdale
Instagram: C10sofOC
