Re: Wannabe Wrencher from Colorado
AJBERT, it looks like we live very close to each other. Sweet.
Ski-me, I do have some and I'll try to post tomorrow. As far as plans, I've identified some stuff that requires attention before I'm off and having fun. I purchased a battery and a new set of tires today. The exhaust manifold is cracked so it sounds neat but needs addressed. It's currently stuck in first gear (partly why I got it for so cheap) and I need to disassemble the linkage and try to manually place it in neutral. Safety considerations: Oil looks clean and doesn't smell like fuel but I'll change it anyway. Didnt find oil in the coolant so thats good. Brakes work and plenty of pad left in front. Im not good with drums so I'll need to figure out how to check the status on those... Whats been done: The 350 has been bored and cammed. It has a Holly carb and nice cleaner (haven't checked which one yet). Its been lowered but I'm not sure how...I assume the coils were cut and thats it. It has an electronic fuel pump with an on/off switch in the cab. Im assuming he wired it directly into 12v. I was able to find a # on the gear box and found out the transmission is a Saginaw 4speed. So....Lots of fun and work ahead! |
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
Thanks, I appreciate it. I guarantee you I will have a ton of questions over the next few months while I learn figure this thing out. I'm going to start digging in here when I get off of work. How do you suggest I go about it without being annoying? I have a few issue I will need to solve right off the bat. Should I post my questions separately on the forum or start a build thread with multiple questions? I know I'm going to have questions regarding the gearbox, leak at the tranny/driveline, and exhaust manifold break.
Also, which shop/repair manual is a must have for my 72 c10? I'd like to get that on order asap. Please suggest any other reading material I'll need. I haven't forgotten about pictures. I have been at work since I started the thread. I will get some more pics in the next few days. Thanks for the warm welcomes. Jered 1987, I'm not sure about the suspension. It appears to be stock with heated/cut coils for the lowering. The engine is the 350 and I was told it was bored and cammed but the guy had no idea what the previous owner did. It has a Holly carb and I haven't had time to look at which air intake is mounted but it looks nice. The tranny was a mystery but I looked up the number on the casing and it came up with a 4 speed saginaw. I just got the thing and headed off to work without inspecting the body too awfully much but it appears straight and I don't suspect tons of filler. I test drove the truck quickly during the daytime and i couldn't turn down the offer so I picked it up that night without being able to inspect everything real close. For 1800 bucks, I felt I couldn't go wrong with this project. The guy I bought it from really wanted to learn the ropes and fix it up himself but time got away from him and I think his wife wanted the thing out of the driveway ![]() Last edited by Tellerbama; 12-02-2017 at 12:54 AM. Reason: forgot to reply to someone |
![]() ![]() Join Date: May 2015
tellarbama..for a sec there from your name I though you was from my neck of the woods..your def inn the right place...
skime.....( ..how can he have "0" posts?!?..)..you get no post counts in the welcome area forum...
