#26 |
Re: Radiator Support Install ???
Anyone??
#27 | |
Jon
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#28 |
Scrapper 1
make sure you double Nut the bolt.But a nylon nut in there ot makes taking them off for any reason easier
#29 |
Hopefully this helps you. This is what i went of and had no issues!
#30 |
oops... wrong years, my bad,
#31 |
No, your good it's up to '68.
Thanks, Jon
#32 |
Responding to this old post but is there any way to go around having to remove the radiator and everything else that is getting in the way of me inserting the bolt from the top of the core support? I have a 1970 c10. Thank you all for the support.
#33 |
Now I have an issue. I just went and checked the 67 parts truck I have for my 71 restoration. In checking the radiator mounts, they are "both" flush with the top of the frame. No, the vin tag no. and the frame numbers are not the same and there is the number 7--5--7 stamped into the pass. side frame below the frame ser. number. I am thinking I have a 71 cab on a 67 frame??
#34 |
I just went through this recently with my '67.
I just went to Lowes to their fastener section and got all the parts necessary to duplicate the LMC page's front 67-68 core mounts ( including the thick rubber washers and everything else ). I just slid the radiator to one side while I mounted the other side and then vice versa. Didn't have to do anything special and didn't need OEM parts. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#35 |
I got my set from a forum vendor, Classic Heartbeat. The owner answered all my questions each time I called. Fit has been excellent.
I am not quite finished with installing mine...as I had to loosen those to get the front end back on. Last edited by In The Ten Ring; 10-11-2017 at 07:06 PM. |
#36 | |
1968 LWB C20 / AC / Wood Bed |
