Old 11-26-2017, 02:56 PM   #1
Bobbed72
Bobbed72's Avatar
How much trouble did I buy myself?
Got this 5.3 from a seller who got it from a wrecking yard. Highly suspicious that it did not coming directly out of a running truck. How hard is it to clean up?
https://i.imgur.com/TS3zhXM.jpg
Bobbed72 is offline   Reply With Quote
Old 11-26-2017, 04:56 PM   #2
mongocanfly
mongocanfly's Avatar
Re: How much trouble did I buy myself?
whoa!!!wow!!!....I'd be getting my money back if you bought it as a running engine.....if your gonna keep it a total rebuild is in your future..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-26-2017, 06:00 PM   #3
Bobbed72
Bobbed72's Avatar
They claimed it was running but I got it for $500 and was contemplating a rebuild either way. Just want to be sure I'm not gonna rack up costs too much outside of a rebuild.
Old 11-26-2017, 06:01 PM   #4
Bobbed72
Bobbed72's Avatar
To clarify. They said they heard it run over the phone. No way to verify the engine they heard is the one they got.
Old 11-26-2017, 06:47 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thats a donor block, and only if you hot tank the hell out of it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-26-2017, 06:50 PM   #6
Bobbed72
Bobbed72's Avatar
Donor block?
Old 11-26-2017, 07:14 PM   #7
mongocanfly
I'm betting the one they "heard" over the phone is not the one you took home...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-26-2017, 07:55 PM   #8
hjewell2
hjewell2's Avatar
uhh ya that motor has not run for awhile. get your money back.
reminds me of the ads on craigslist, MOTOR RAN WHEN PULLED.
hjewell2 is offline   Reply With Quote
Old 11-27-2017, 12:19 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Bobbed72 View Post
Donor block?
Good for the block and not much else. Thats gotta fully come apart, and depending on the amount of corrosion etc in the cylinders, a lot of things might not be reused. Its not a clean n run kinda thing..and if the block looks like that, I'm sure the heads and other things attached aren't in great shape either.
Old 11-27-2017, 02:03 AM   #10
Bobbed72
Bobbed72's Avatar
Heads look good. One rocker had corrosion on it and I'm not so sure about the lifters. Crank spins.
Old 11-27-2017, 09:46 AM   #11
rapid49
rapid49's Avatar
Clean it up and take a closer look . If the water got into the engine after it was running and did not stay long enough to cause any damage it may clean up . If there is any pitting in the cylinders it will need to come apart and bored.
rapid49 is offline   Reply With Quote
Old 11-27-2017, 10:53 PM   #12
izzy_Britton
izzy_Britton's Avatar
I was thinking if the water got into the lower end, you may need to replace or regrind, or at the very minimal polish the crank bearing surfaces, and likely the cam too.
stick that thing on an engine stand, flip it over and start pulling it apart. if your cylinders are corroded your looking at a very minimal a heavy hone job, likely a bore and if you do a bore new pistons. IMO you bought a core engine, hopefully a rebuildable core.
IF you can get your $$ back, i would !!!
for 500$ did you get anything other than the engine? intake? throttle body? wire harness? anything?
I wonder if the seller got into it as far as you did and just decided to unload it.
IF you can get your $$ back, i would !!! you can find better condition engines for similar prices or even if you spent more on a better engine you really honestly would be money ahead.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 11-28-2017, 01:35 AM   #13
Bobbed72
Bobbed72's Avatar
have everything but the harness and ecm. around here 500 is half what I've seen them go for. Some milky oil in the pan.
I'm tempted to rebuild it.
Old 11-28-2017, 01:44 AM   #14
Bobbed72
Bobbed72's Avatar
Cleaned out and I wiped down the cylinders with oil. Looks a lot more promising.
https://i.imgur.com/koGFgTa.jpg
https://i.imgur.com/J57CvZT.jpg
Old 11-28-2017, 10:57 AM   #15
scoot_mcgrute
Did the intake have any holes in it? My 5.3 was pressure washed before I got it and the cam position sensor was out of it and some of the plugs were missing from the intake so water got inside from that only. Mine wasn't that bad but we soaked up all the water, cleaned it real good and I've been running it. The cylinder walls looked really good after we got the water out too.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 11-28-2017, 01:51 PM   #16
Bobbed72
Bobbed72's Avatar
I didn't see any. One side of spark plugs were loose and the oil fill is missing the cap. Owner said he cleaned it up. Try to peek in the manifold and see if there is any moisture.
What did you use to clean up the cylinders?
Old 11-28-2017, 05:03 PM   #17
Custom 68
Custom 68's Avatar
one thing oversized pistons are pretty pricey (IMO) for these so if you need to bore this it will cost more than a standard sbc if I remember correctly.
but I would at a minimum take it all apart it should bet new bearings and not just clean up the bore. But it sounds like you had a rebuild in mind anyway.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-28-2017, 05:34 PM   #18
Bobbed72
Bobbed72's Avatar
Yeah just looking at summit the LS pistons are twice as much.
A little part of my brain said I should rebuild anyways just to be sure I didn't have a problem down the road. Not in a hurry to drop it in. Can wait till summer to do that.
You guys have been real helpful. Expect a lot more questions from me for the next few months.
Old 11-28-2017, 07:00 PM   #19
Bobbed72
Bobbed72's Avatar
Here's a shot of the crank.
Old 11-29-2017, 12:59 AM   #20
scoot_mcgrute
I used an industrial degreaser that my buddy gets me and a brass brush to clean it all up
1966 Army Truck
Old 11-29-2017, 05:38 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you get it apart and have it tanked, at least you can be sure that all the coolant and oil passages will be free of gunk. Then if the block looks good naked, you can see if a simple hone will clean it up enough. The rest just bolts together with cleaned up old parts if so.
Obviously things like spun bearings or other findings can change that, but you really can't go anywhere with the block together as it is.
Old 11-30-2017, 09:45 PM   #22
Bobbed72
Bobbed72's Avatar
Well I pulled all the rods to get a good picture of the cylinders and the rod journals.
No spun rod bearings.
Haven't pulled the crank yet. But it spins pretty easy.
One cylinder looks scored but I can't feel a groove.
Ordering a Flex hone.
Old 12-01-2017, 02:03 AM   #23
izzy_Britton
that doesnt look too bad.
Old 12-01-2017, 06:09 AM   #24
NC_John
NC_John's Avatar
Like BR3W CITY said.... check the cooling jackets for sludge/gunk. I thought my 6.0 pullout was good to go until i pulled a head and saw the dexcool mess. From there it had to go the machine shop to get cleaned out and from there things got way out of hand because I am easily persuaded and have a slight HP problem.
ME. "i just want it cleaned up for a basic rebuild. I'm going to build a stroker in a couple years with it."
SHOP. "Well, its here now. Do you want to go through all this again later or just do it once now?"
ME (no hesitation) "OK. Makes sense. I want 500 hp at the flywheel"
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 12-01-2017, 12:28 PM   #25
Bobbed72
Bobbed72's Avatar
Feel I'm in the same boat. If i take it for a hot tank and the machine shop tells me it should be bored I'll just be like "make em as big as you can"
