Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 11-16-2017, 09:05 PM   #1
IllinoisK30
Active Member
IllinoisK30's Avatar
WTB Neutral Safety Switch Terminal End Manual Trans
I’m looking for the terminal end for my neutral safety switch on my ‘77 Chevy. The PO just butt connected the wires to by-pass the faulty switch.
The wires going to it are purple and purple with a white tracer. I had another harness saved from a’78 with four speed but somebody did the same thing! I couldn’t believe it, so I need the terminal end that the two purple wires go into or that terminal end with the wires in it so I can just solder it on to the existing wires.
I’m not sure if anybody can help but I sure would appreciate any. Please see the pictures for reference Thanks.
IllinoisK30 is offline   Reply With Quote
Old 11-17-2017, 12:39 PM   #2
IllinoisK30
Active Member
Re: WTB Neutral Safety Switch Terminal End Manual Trans
This is a picture of the plug I’m looking for.
Old 11-18-2017, 06:03 PM   #3
1774btcrew
1774btcrew's Avatar
I have one $22 shipped. Most of the time these are bypassed just like yours.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-18-2017, 08:12 PM   #4
wahl4m
if you cant find one ??? ck napa -i believe they have a universal one that might work ? so many things are being discontinued these days ?? good luck -im doing one that was bypassed but everything is still there !
wahl4m is offline   Reply With Quote
Old 11-18-2017, 09:05 PM   #5
IllinoisK30
Active Member
Thanks, I appreciate it. I will check. Your lucky, nobody wants to fix things right these days!
Old 11-18-2017, 09:35 PM   #6
bluex
bluex's Avatar
Do you have a part number for the switch you have pictured? I need something to put on my 78 that I have converted to a manual trans.
bluex is offline   Reply With Quote
Old 11-18-2017, 11:10 PM   #7
IllinoisK30
Active Member
PM sent.
Old 11-18-2017, 11:17 PM   #8
IllinoisK30
Active Member
Part number for switch is 336248.
Old 11-18-2017, 11:30 PM   #9
IllinoisK30
Active Member
I forgot to mention the part numbers for the bolt and nut. The bolt is pretty special and will need to get. There pretty cheap on ebay. The nut probably a big box store will have. Both are plastic.
Bolt-336250
Nut-336296
Old 11-19-2017, 11:50 AM   #10
bluex
bluex's Avatar
Thanks for the info man!
Old 11-19-2017, 12:08 PM   #11
IllinoisK30
Active Member
You bet!
Old 11-19-2017, 02:57 PM   #12
bluex
bluex's Avatar
So for anyone else who might be looking looks like the 336248 was replaced with 14013141 which was replaced with 14074333. All are discontinued.
Other options:
Standard motor products NS12 -discontinued
AC Delco D2211A -discontinued.
I did go ahead an get the bolt off eBay though. There are some switches out there but man they are pricey imo. You can get an 85+ one for like $11 but most of these are $40 or more. Guess I'll have to bite the bullet on one eventually.
Old 11-20-2017, 05:54 PM   #13
1774btcrew
1774btcrew's Avatar
Shipped out today
Old 12-01-2017, 08:43 PM   #14
bluex
bluex's Avatar
If anyone finds this later I got a switch an installed it today. The pigtail off the neutral safety switch from the column fit this switch perfectly. The wires were even long enough to reach it without modifying them.
