Re: oxygen sensor yes OR no ?
A Heated O2 Sensor can heat itself, while the stock O2 sensor relies on the engine heat to heat it up.
You said someone put dual exhaust on - did they remove the factory manifolds and replace with headers? I ask because the 02 Sensor goes into the manifold, not the Y-pipe. If you still have stock manifolds you should have a port for the 02 sensor. |
| Bookmarks |
