![]() Join Date: Oct 2009
Re: Confused
I believe it's a Cheyenne that's had the super woodgrain on the dash and gb added (Z84 Cheyenne did come with woodgrain on the doors) - but it is an original swb truck per the SPID wb and model # and gvwr ratings. As far as "Super-ness", it's missing the stainless tailgate sleeve (not that that is definitive proof of anything - but is an oft-overlooked indicator). Vinyl seat is a giveaway if original (but it looks like in very good condition, so could be a replacement - it you think it's original, that's another indicator it is Z84 Cheyenne-only as that is a Cheyenne level seat cover only). Stock seat cover for a Super would be blue custom cloth (i.e. houndstooth). Can understand your frustration - but unless you paid BIG dollars or had heart set on a Super, that's a sweet original swb Cheyenne. CE10734 model # is correct for a SWB 1/2 ton 2WD (C10) fleetside with a V8 (and yours was ordered with the optional 350 upgrade).
EDIT: Someone DID go out of their way to add factory a/c - that's interesting (and tilt, and tach - so all this leads me to believe a po just upgraded to Super trim status and also added tilt +a/c in the process as well at the same time). Does the a/c look factory in the engine compartment? I wonder if an a/c dash was swapped over or if the holes were cut after the fact. Looks like they did a decent job! Excellent color combo. Dk blue not "that" common. Last edited by jocko; 12-04-2017 at 10:51 PM. |
