Old 12-04-2017, 06:53 AM   #1
Toms67
Toms67's Avatar
Help me plug this hole.
Can't find anybody that sells a grommet for this hole. It is located just below the gas pedal. Backing plate grommet is too small. Any help would be appreciated. Thanks.
Toms67 is offline   Reply With Quote
Old 12-04-2017, 06:55 AM   #2
dennislbrooks
dennislbrooks's Avatar
Re: Help me plug this hole.
Flexseal tape cut to fit.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 12-04-2017, 07:36 AM   #3
randy.powell
Looks like an emergency /parking brake cable grommet...
Randy
randy.powell is offline   Reply With Quote
Old 12-04-2017, 08:51 PM   #4
Toms67
Toms67's Avatar
It's a 67. Parking brake cable Is under the steering column. I have no idea what went there. It is under the Excelerator pedal. Too far over to be the emergency brake cable. RTV I guess.
Old 12-04-2017, 10:04 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
What size is the hole?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-04-2017, 10:17 PM   #6
harpo231
harpo231's Avatar
Ace hardware
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-05-2017, 12:14 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
foil tape- inside and outside
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-05-2017, 05:01 AM   #8
Toms67
Toms67's Avatar
The hole size is just a little bigger then the plug for the backing plate adjuster hole. Not a biggie. But it does seem to be a factory hole. I will plug it with something. Thank you for all the replies.
Old 12-05-2017, 05:17 AM   #9
In The Ten Ring
What are the dimensions of this hole?
Assuming it is big enough, you could fashion two steel plates to bolt into each other and tighten up, sandwiching the firewall between. Use pan-headed machine screws (actually one would do) and put the head of the machine screw on the inside (of the cab). You could use some sealer around the edge or even some foam gasket material from Lowe's to keep out moisture.
In The Ten Ring is offline   Reply With Quote
Old 12-05-2017, 05:24 AM   #10
Killer Bee
Killer Bee's Avatar
one of these possibly fit or close enough to be trimmed?
square push in plugs https://www.mcmaster.com/#square-plugs/=1ajrscd
square snap in plugs https://www.mcmaster.com/#rectangular-plugs/=1ajrsyd
rectangular push in plugs https://www.mcmaster.com/#rectangular-plugs/=1ajrtab
rectangular snap in plugs https://www.mcmaster.com/#rectangular-plugs/=1ajrtji
or one of these maybe? https://www.heyco.com/Hole_Plugs/pro...ion=Hole_Plugs
Old 12-05-2017, 07:45 AM   #11
Toms67
Toms67's Avatar
Thank you. I will definitely check into that. Thank you for the help.
