04-21-2004, 05:06 PM | #1 |
Gear or not to Gear that is the ?
I have a question (?). I have a mid to late 80's 12 bolt 5 lug 1/2 ton rear end . Will the gear's ( 3rd member) fit or interchange with a 69 12bolt 6 lug 1/2 ton rear end. Befor I start tearing things apart. PLEASE HELP My only means of trasportation right now.
67heaven327 |
04-21-2004, 05:12 PM | #2 |
Formerly yellow72custom
Yes, it should go right in. You will have to set up the gears though.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
04-21-2004, 05:35 PM | #3 |
Thank's "yellow72custom" for the quick reply. I'm kind of new to this, can you explain "set up the gear's " please. I'm learning as I go. I'm quick learner. THANK'S so cal tz
67heaven327 |
04-21-2004, 05:47 PM | #4 |
I haven't done it (yet) but it is fairly complitcated....check out this post.
http://67-72chevytrucks.com/vboard/s...t=rebuild+rear
04-21-2004, 06:14 PM | #5 |
Thank's again "yellow72custom" for all the info. and the quick reply on my dier need help. Thank's " so cal tz"
67heaven327 |
04-21-2004, 06:16 PM | #6 |
No problem. BTW, welcome to the board from Missouri
