Old 04-21-2004, 04:57 PM   #1
ACP427
ACP427's Avatar
about 2" drop on front end Help
I wanna drop the front end of my 68 chevy c-10 , can I just install 2" drop springs or do I need the 2" drop spindles too? thanks Tony
ACP427 is offline   Reply With Quote
Old 04-21-2004, 05:07 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
If you do the 2" drop springs, then you will need an alignment.
If you do just the 2" drop spindle, then you should not need the alignment.
If you do both, it would then be a 4" drop....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-21-2004, 05:15 PM   #3
ACP427
ACP427's Avatar
2" drop
thats it? I will need an alignment anyway after I install disc brake spindles and all new front end parts, with the big block installed now it my be close to a 3" drop ! thanks John hey your not the same john fabris from syracuse are you?? thanks Tony
Old 04-21-2004, 07:50 PM   #4
John Fabris
TOTY 2006
Not the same JF, there are 7-8 of us in the US.
Did you buy a kit for the front?
John Fabris
67 C10 SWB
Old 04-21-2004, 08:11 PM   #5
ACP427
ACP427's Avatar
kit
No , I am much too cheap for that ! I bought a 71 rolling frame and took the lower a arms, spindles and rear axles , and I am installing new moog front end parts ball joints tie rod ends etc. I bought a nice piece of 68 trim from you on e-bay and still need a couple more pieces of that if you get any , let me know thanks Tony
