Old 12-06-2017, 02:41 PM   #1
sixty4bigwindow
sixty4bigwindow's Avatar
Vibration, driveline not center, and wheel measurements off?
Hello my trusty forum guys/braniacs all things Chevy c10's! Another question to seek input on. After a long time of running the rear suspension sitting on the overload leaf springs, I found some 02 wrangler rear springs and set those in, thus lifting it back from the load leafs, and it dropped it from stock about 3" or so (no exact measurements taken.) With the drop spindles in front, and some chopped springs, it was raked like a dirty hooker on Saturday night. So, I leveled it out a bit by putting some uncut springs back in the front. Here is where my issues have begun.
I now notice something like a vibration, or shudder possibly, during a low speed takeoff from a stop. I know that driveline angle can affect things like that, and always needs to be considered when doing any drop, lift on suspension. Another thing I noticed, is after these adjustments, my driveline looks to be closer to the driver side of the trailing arm crossmember hole, and measuring the rear to front tire, it looks like the driver side is 1/2" shorter.... My question is, are all of things connected, should I shim the axle in the back with such little drop, and am I risking damage to my Bruce Jenner? Thank you guys so much!
sixty4bigwindow is offline   Reply With Quote
Old 12-06-2017, 02:53 PM   #2
PGSigns
PGSigns's Avatar
Re: Vibration, driveline not center, and wheel measurements off?
When you drop the rear you need an adjustable track bar to get it back to the center. I prefer the long ones like the ECE super track bar. Trouble with doing a wheel base measurement to the center of the wheel its hard to tell if the wheels are pointing straight in relation tot he rear.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-06-2017, 03:32 PM   #3
sixty4bigwindow
Ok, that's what I thought too about the alignment. I looked at the front wheels, and the alignment is definitely off, and I can feel it when I drive too, steering kinda "floats." And the track bar is the panhard bar, right? Axle to rear frame crossmember? There is no adjusting the stock one then I'm guessing?
Old 12-07-2017, 07:49 AM   #4
PGSigns
PGSigns's Avatar
No adjustment on the stock one. You can measure from the wheel to the frame on each side in the rear and see how much it is off. On the alignment they were not the best stock with very little caster. There are two threads in the suspension to read that will get you a bit more up to speed on these trucks. One is the make it handle thread and the other is the caster mod thread. On mine I did the caster mod (1/2") and now run 4 degrees of caster in the front and that tightens the feel over the 1 degree or so stock. I also have a 2 degree wedge in the rear trailing arm mounts for the rear end to correct the pinion angle.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-07-2017, 08:18 AM   #5
Greg63
Enjoy your truck
Greg63's Avatar
Should the rear wheel to frame measurement be made with the vehicle on or off the ground?
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 12-07-2017, 02:40 PM   #6
racecougar
racecougar's Avatar
Greg.
At ride height.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-07-2017, 04:51 PM   #7
sixty4bigwindow
Ok, I am taking it in to get aligned next week. Ill talk to my guy and see what he recommends. The driveline vibration and tranny killing stories always concern me.
