09-24-2017, 07:31 PM | #526 |
Re: 67 GMC super custom build
Starting to reassemble the steering column
09-27-2017, 07:10 PM | #527 |
The 1 1/4" ton front sway bar v's original 1967 7/8" bar. It's Double the size. The big one is going in!
10-09-2017, 06:37 PM | #528 |
Rear tire difference. Same size rims.
10-19-2017, 09:23 PM | #529 |
Got my rotors back from powdercoat today. They took longer cause I had to wait till they had enough stuff to do in silver high heat powder. I'll have them turned when I get to the point where brakes need to be functional.
10-20-2017, 12:50 AM | #530 |
70+ ( Old Skool Club )
Nice
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-22-2017, 12:03 PM | #531 |
Got the rest of my zinc plating done. Some of the brake parts weren't colored to the theme of the chassis so I had the rest of it finished up. Now I can assemble a ton of stuff. Got the original door hinges done. No paint. All done in zinc.
10-22-2017, 12:22 PM | #532 |
When you start putting your truck together it'll be like assembling a new one.
10-22-2017, 12:54 PM | #533 |
Yep. Can't wait till that starts. Dang bodywork standing in the way lol
10-23-2017, 05:23 PM | #534 |
Got the tilt telescopic column completed. If you didn't know you would think it could have been factory.
11-05-2017, 08:38 PM | #535 |
I got my washer bottle finished up tonight. I riveted a terminal to the bottom of the bottle and a rod thru the top. When there is water in it and it is above the metal rod the light will stay off. When the water level is below the metal rod the light will turn on letting me know the fluid is low. The fluid itself completes the ground circuit. The terminal on the bottom goes to the washer pump ground so the light will only come on when the washer is pumping.
11-06-2017, 01:52 PM | #536 |
I like the washer fluid low-level indicator setup. What kind of circuit are you using to turn the indicator light on? Got a schematic?
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
11-06-2017, 03:23 PM | #537 |
Is that a factory deal??? Just wondering, I have not heard of such. Where is the indicator light?
I like that setup. The mickey mouse pump situation on the motor is a pain......... |
11-06-2017, 08:23 PM | #538 |
It's actually a 71 to 74 gm coolant level accessory. I just adapted it to washer fluid and made the light work next to the wiper wording on the gauge bezel. Gm Part # 364002. The pump is from a 75 Vette. They are common on ebay and relatively Inexpensive swap.
11-09-2017, 04:10 PM | #539 |
The radio is now completed as well. Had the face re-chromed and all the buttons re-chromed as well. New truck style lens. I also sent it back to Greg at electro tech and had him install a auxiliary from the back of the radio so I can play my phone. I'll prob run a cable to my console when I get that far. I am super happy with how this turned out. I would recommend electro tech for all your radio needs. Greg is great to work with. I used his speakers as well. Here is a video as well of it all working together.
https://youtu.be/Gw6kgttLmhw Last edited by chewychevy67; 11-14-2017 at 09:38 AM. |
11-09-2017, 04:36 PM | #540 |
Nice setup!!!
11-10-2017, 02:16 PM | #541 |
Awesome!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-12-2017, 08:57 PM | #542 |
Rear sway bar finished! And cleaning up the front disc brakes as well.
12-06-2017, 09:06 PM | #543 |
Picked up this spare tire lock for my spare I'd I mount it in the bed instead of underneath. I think I could use it for a underneath one as well if I got creative.
12-08-2017, 11:39 PM | #544 |
Here is how the spare tire lock looks installed.
12-08-2017, 11:46 PM | #545 |
That is a very cool touch Keep up the good work uncle!
12-09-2017, 05:02 PM | #546 |
Looks like it belongs
01-09-2018, 08:04 PM | #547 |
What kind of paint did you use for that steering wheel center cap? Looks great!
1968 LWB C20 / AC / Wood Bed |
01-10-2018, 10:16 AM | #548 |
Your attention to detail is amazing. I LOVE the wheel/tire setup. I can't wait to see this thing completed.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-10-2018, 01:23 PM | #549 |
Looking great!!!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
01-11-2018, 01:12 PM | #550 |
