Old 12-08-2017, 08:49 PM   #1476
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by Number98 View Post
What is your plan for hood hinges?
I have a set of cowl-mounted Porterbuilt hinges powder coated and ready to go, but I have to install a cowl first...
Originally Posted by CC69Rat View Post
It has been a while since I've seen your truck my friend. It looks incredible, nice work.
Thanks a lot! Looks like a bunch of work left to me, haha
So, I removed the inner cowl today to get rid of the rust problems. Seems the rubber that PO used to fill the wire run collected water underneath and rotted the firewall. I’ll have a fair amount of repair to do before installing the new metal.
While I had the wire wheel on the grinder cleaning rust, I decided to start removing the undercoating or bedliner or whatever it is from the firewall. I ended the day looking like a coal miner, but glad to have made some progress.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-08-2017, 08:53 PM   #1477
builtbyKane
builtbyKane's Avatar
That is never any fun, but what a difference already. Great job.
builtbyKane is offline   Reply With Quote
Old 12-08-2017, 10:48 PM   #1478
sprint_9
sprint_9's Avatar
Wow that looks like alot of work, it will all be worth it in the end, keep up the good work.
sprint_9 is offline   Reply With Quote
Old 12-08-2017, 10:53 PM   #1479
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the kind words. Not fun, per se, but definitely gratifying. I am enjoying the opportunity to get in there and make it ‘right’. I was getting a little excited identifying all of the holes I want to weld up.
-Chris
Old 12-09-2017, 01:18 AM   #1480
SCOTI
SCOTI's Avatar
So...... more damage than expected?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-09-2017, 09:45 AM   #1481
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! I have a vision of the finished product that makes it all worth it
Meh, it’s about what I thought would be there. Lots of little holes along the wire run. I’ll have to do some interior disassembly before proceeding, to keep from starting a fire while welding
-Chris
Old 12-29-2017, 01:17 AM   #1482
gringoloco
A guy with a truck
gringoloco's Avatar
Took a break from the messy cowl/firewall to deal with the messy engine. She was nice and clean on the inside, though. Can’t wait to get to the no gloves required, re-assembly part...
-Chris
Old 12-29-2017, 06:55 PM   #1483
gringoloco
A guy with a truck
gringoloco's Avatar
Oh yeah, I’m digging this:
-Chris
Old 12-29-2017, 07:26 PM   #1484
SCOTI
SCOTI's Avatar
Who's VC adapters?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-29-2017, 09:30 PM   #1485
gringoloco
A guy with a truck
gringoloco's Avatar
Who's VC adapters?
They’re from CFR Performance. They mount the coils under the VC, have provisions for PCV, and utilize the stock valve cover gaskets.
-Chris
Old 12-30-2017, 10:38 AM   #1486
sprint_9
sprint_9's Avatar
Thats gonna look good. I always toyed with the idea of making my LS look old school, Im excited to see it come together.
Old 12-30-2017, 10:32 PM   #1487
BustedTruck
BustedTruck's Avatar
Thank you for all the detailed post. I am in the same place with that inner cowl. Looking forward to your take on it.
BustedTruck is offline   Reply With Quote
Old 12-31-2017, 01:27 AM   #1488
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, I dig it, too. Though, back when I first had this idea, not many people were doing LS swaps this way, now it seems everyone is. May have to change it up just a bit...
I like to give detail in hopes that it may benefit someone else. Can’t tell you how many times this forum has helped answer questions for me. Can’t say I’m looking forward to the cowl work, though. More like putting it off
-Chris
Old 12-31-2017, 08:33 PM   #1489
shearjs
shearjs's Avatar
So cool! Everything looks great. Digging the engine ideas.
shearjs is offline   Reply With Quote
Old 12-31-2017, 08:43 PM   #1490
mjensen
mjensen's Avatar
Looking good!!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-02-2018, 08:10 PM   #1491
Last_Paladin
Along for the ride.
Last_Paladin is offline   Reply With Quote
Old 01-02-2018, 10:32 PM   #1492
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by mjensen View Post
Looking good!!
Originally Posted by Last_Paladin View Post
Along for the ride.
Thanks guys, and welcome to the circus.
After chasing the elusive 9/16” grade 8 hex and 7/16” grade 5 carriage bolts all over town because my normal bolt supplier was closed for the holiday, I managed to get the new cab mounts installed. The old rubber ones had been previously replaced with LMC units and weren’t that bad, actually, but the core support bushings were pretty well shot.
The cab has not been square on the frame since I’ve owned this truck, which caused misalignment issues with the bed, fenders, cowl, and hood. When I measured it, it was around 3/8” off side-to-side I figured while the truck is torn apart, it’s a good time to straighten it out and replace bushings. I greased the crap out of the Prothane mounts with Energy Suspension’s super gooey grease and torqued her down in the correct position. We'll see how much shimming it needs upon reassembly...
-Chris
Old 01-04-2018, 09:26 PM   #1493
gringoloco
A guy with a truck
gringoloco's Avatar
The valve cover adapters are for sale here, if anyone is interested:
http://67-72chevytrucks.com/vboard/s...d.php?t=753953
They sell for $200 plus new, these were only used for mock-up. Nothing wrong with them, just decided to go a different route.
-Chris
Old 01-05-2018, 04:36 PM   #1494
gringoloco
A guy with a truck
gringoloco's Avatar
Worked on tearing down the interior so I can continue with the firewall and cowl repairs. Figured now was as good a time as any to get the high hump cut out...
-Chris
Old 01-05-2018, 05:15 PM   #1495
SCOTI
SCOTI's Avatar
Hhmm......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2018, 10:20 PM   #1496
gringoloco
A guy with a truck
gringoloco's Avatar
Hhmm......
Yeah, if I could just make up my damned mind, this project would go a lot faster (and cheaper)...
In other news, I got the majority of the upper firewall rust taken care of and mocked-up the new inner cowl panel. It is a surprisingly good fit, but will need some massaging and smoothing (along with the firewall) before final install.
-Chris
Old 01-06-2018, 12:47 AM   #1497
Kronald_70GMC
Kronald_70GMC's Avatar
Looking good! I like your attention to detail. Keep up the good work!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is online now   Reply With Quote
Old 01-10-2018, 11:49 AM   #1498
knomadd
knomadd's Avatar
Nice work! Keep it up. Curious what your different route is for the valve covers. I have a set of those CFR adapters that I have plans to use in the future. Haven't brought myself to put them on yet though.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-10-2018, 12:37 PM   #1499
GAc10boy
GAc10boy's Avatar
About to tackle this on my '68. Can you give me a little more detail in what tool you used to cut the floor and any tips you have to make sure it's right. Yours turned out great! Were your high hump bolt holes already in your floor or did you drill before you cut out low-hump?
My first time going from low-to-high and I want to make sure I do it right the first time.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 01-10-2018, 02:11 PM   #1500
SCOTI
SCOTI's Avatar
I did this on my 68 & my 64. The high humps are slightly different for each series but the install was the same. I set the high hump over the stock floor & used a sharpie to reference mark the hole locations.
The stock floor basically has a formed body line in the floor that pretty much can be used as the cutting guide. You want to leave enough material past the reference holes so there's a decent flange when bolting the hump.
Really was pretty straight forward for both models.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
