Old 12-11-2017, 11:23 AM   #51
Richard2112
Richard2112's Avatar
Re: Back to the Basics: Re-Sealing a leaky power steering box
Great tutorial. I will be referring to this in the near future. To bad photobucket had to impose their damage to another fine thread. Even got the one at Pirate4x4
Richard2112 is offline   Reply With Quote
Old 04-24-2018, 11:26 AM   #52
volvo.moose
Might want to rehost the photos on imgur or something. Looks like photobucket is holding them hostage.
volvo.moose is offline   Reply With Quote
Old 04-24-2018, 11:49 AM   #53
zosoppp
depending on the browser you use there are photobucket workaround applets that can restore the images for you.
For Firefox I'm using the "Photobucket Hotlink" extension. (think it would work in chrome too but not certain)
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is online now   Reply With Quote
Old 04-24-2018, 12:02 PM   #54
volvo.moose
Works perfect in chrome. Thanks for the tip!
Old 12-24-2018, 01:05 AM   #55
gearheads78
gearheads78's Avatar
So Ive done a ton of stuff but never rebuilt a steering box (until today) Managed to get it all the way apart and back together working perfectly on the bench lock to lock smooth. Installed back in the truck and still smooth lock to lock. Added fluid and was turning the wheel while off to fill and bleed. Iafter about 4-5 lock to lock turns it got a stiff spot about 3/4 to lock on the right will go past it but there is a pop inside the box. Anyone ever run in to this and think they might know whats going on? Im petty sure all the balls were put in alternated but if I mixed up 2 could that be it? The color was so close it was hard to tell.
gearheads78 is offline   Reply With Quote
Old 11-07-2019, 01:37 PM   #56
davischevy
davischevy's Avatar
Sub'd.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is online now   Reply With Quote
Old 09-05-2020, 05:21 PM   #57
dmjlambert
dmjlambert's Avatar
I'm doing this procedure, so I made a booklet with non-polluted pictures. I cropped a couple of the pictures and made minor spelling and punctuation changes. I included the follow-on discussion where questions were asked and answers provided, or just additional information provided. I printed it out and put it in a 3-brad school folder, and heading out to the garage.
https://pdfhost.io/v/K3p.eMnvo_TX_Fi...ng_gearbox.pdf
Old 09-05-2020, 07:27 PM   #58
The Rocknrod
Moderator
The Rocknrod's Avatar
Excellent booklet of Tx Firefighter tutorial.
Old 09-06-2020, 09:19 PM   #59
CG
BlahBlahBlah
Thanks for doing this with the tutorial. I printed it out double sided and its in my 67-72 folder. Not to just disappear like so many things magically do on my computer =)
Old 09-07-2020, 12:42 PM   #60
SCOTI
SCOTI's Avatar
Impressive & cool that you shared it!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-22-2020, 07:39 PM   #61
Love 70 Chevys
Love 70 Chevys's Avatar
Awesome write-up! Got my truck running for the first time in 15 years this weekend and the non-pitman bearing spewed out all the fresh new fluid in about five minutes. Your write-up is really going to make this a fun little project. I like the way you explain things. (Twice even!)
Love 70 Chevys is offline   Reply With Quote
Old 09-23-2020, 01:51 PM   #62
KMC3420
KMC3420's Avatar
This is a great thread, I always enjoyed TX firefighters informative posts..I see he hasnt been on since 2017, what ever happened to him?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 09-23-2020, 02:39 PM   #63
SCOTI
SCOTI's Avatar
He focused on other things (work, family, his side hustles, etc...).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-23-2020, 05:55 PM   #64
KMC3420
KMC3420's Avatar
haha, I get that. At times, these trucks or trucks in general come 2nd, 3rd, etc...Hopefully he will return here at some point. Seems like lots of guys take a break at times, then they eventually return.
Keagan
Old 09-25-2020, 11:35 AM   #65
crakarjax
crakarjax's Avatar
He's on IG as well https://www.instagram.com/10mm_nut/
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 06-08-2021, 11:24 PM   #66
Asshat
Asshat's Avatar
I just wanted to ask a couple of questions.
For the input shaft seal:
After re-installing the gland assembly, and it bottoms out and stops, you turn it 1/2" backwards. That is in relation to 1/2" of rotation, or a certain amount of degrees rotation relative to 1/2", correct?
Also, I saw in another ideo that one could make a mark on the gland and on the nut and case to mark where the gland assembly should be after re-assemly. Is this a viable option to consider?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 06-08-2021, 11:45 PM   #67
dmjlambert
dmjlambert's Avatar
After you tighten the gland assembly, back it off by 1/2 inch as measured along the threads.
Old 06-08-2021, 11:50 PM   #68
dmjlambert
dmjlambert's Avatar
I probably would not tend to try to mark it before disassembly and try to line of the same marks when re-assembling. That is because I had success with the above method. Here is another thread where I considered various ways of making this adjustment, and ended up using the back-it-off-by-1/2-inch method. The proper way requires torque wrenches I don't have.
http://67-72chevytrucks.com/vboard/s...d.php?t=812162
Old 04-16-2022, 09:09 AM   #69
72SB
I know this is a old thread but one of the main reasons I joined this forum was to learn 411 like this. Thanks Kevin
Now a 1 day owner of a 72.....and of course with a leaky steering box. My initial thought was I need to replace it but as mentioned most remans are a POS.
I will get the seal kits and do this. First time for me doing a steering box but I have worn that hat 100's of times wrenching since I was 16.
My box has a "S" so I assume its a Saginaw box and has a number 4. Its power steering
72SB is offline   Reply With Quote
Old 12-28-2023, 12:37 AM   #70
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Worth another bump - nice reference Lambert, and great write-up Kevin, as usual.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
