Old 12-12-2017, 08:22 AM   #1
STRUTYOURSTUFF
New girl won't run
Ok , I guess I just need a little advice. Tried starting my 66c10 283, Qjet yesterday. Started up idled for about 15 sec. Stalled. Started again same thing. If I give her gas during this idle she stalls . Tried this about 20 times could not keep her running. Any advice? Thanks
STRUTYOURSTUFF is offline   Reply With Quote
Old 12-12-2017, 08:28 AM   #2
Re: New girl won't run
My guess is fuel, something not fully processing the fuel right. Might have a sticky valve or float in the qjet.
Old 12-12-2017, 08:41 AM   #3
STRUTYOURSTUFF
Thanks Bill was thinking that myself . Needed a little reassurance this morning. This Q jet has been giving issues. I rebuilt it but just can't get it to function properly. Air mixture screws don't seem to do anything.
Old 12-12-2017, 09:57 AM   #4
jnova67
check your accelerator pump shot
jnova67 is offline   Reply With Quote
Old 12-12-2017, 10:12 AM   #5
geezer#99
geezer#99's Avatar
Adjust your choke.
And increase your initial timing.
Old 12-12-2017, 10:31 AM   #6
sirJim
If you havent read this it is well worth your time for a quad.
Float level? Filter in quad? Needle valve hung wrong?
http://www.capitalcorvetteclub.ca/at...ng%20Paper.pdf
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 12-12-2017, 01:21 PM   #7
STRUTYOURSTUFF
Thanks for the info SirJim I will read it. This 283 has a divorced choke system. It looks a little shabby to me. Can I just disconnect that and connect the manual choke cable. If so any particular way to connect it?
Old 12-12-2017, 09:31 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
No way of using a manual choke on a Quad...it just don't work..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-12-2017, 10:56 PM   #9
geezer#99
geezer#99's Avatar
Will too!
Easy to do on a hot air or electric choke carb with a manual choke kit that replaces the black cap.
Or get creative and adapt a bell crank to make a divorced choke carb work.
I’ve done all those.
The bell crank took a bit more experimentation though.
