Old 12-13-2017, 02:13 AM   #1
Fawnzie
Fawnzie's Avatar
Temp range
Hey guys. I just got an 86 square. I replaced the radiator and flushed the whole cooling system and put in a 190 degree thermostat. What should be the normal running temp. It always goes to 210 and stays there. Is this normal? It seems high
Fawnzie is offline   Reply With Quote
Old 12-13-2017, 05:49 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Temp range
that does seem a little high...mine ran around 180s before my LS swap..have you checked the fan clutch?
Old 12-13-2017, 07:19 AM   #3
Dead Parrot
Re: Temp range
IF the gauge is accurate, 210 is about right for a 195* thermostat. The temp on the t-stat is the point it is supposed to start to open, not the temp it maintains. The operating temp will be 10~20 higher then the start to open point.
Don't assume the 31 year old gauge is spot on. Even a 5% variance is +-10 at 200.
Buy or borrow a laser temp reader and check the temp at the t-stat housing and entry point into the radiator once the motor is at operating temps.
Dead Parrot is offline   Reply With Quote
Old 12-13-2017, 09:16 AM   #4
cadillac_al
Re: Temp range
Yeah, if you are talking about the stock gauge that is close enough. My 03 Caddy runs 210 all the time for efficiency.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-13-2017, 11:57 AM   #5
RotaryRocketeer
RotaryRocketeer's Avatar
Re: Temp range
Mine runs 205-210 with a 195 t-stat and one of those terrible flex fans. Nothing to worry about.
RotaryRocketeer is offline   Reply With Quote
