Closed Thread
Old 12-16-2017, 08:09 AM   #6076
Richard2112
Richard2112's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by ghalperin View Post
When I did my frame, I removed over 60 rivets. I have a Snap-On air hammer and used a new Snap-On chisel bit. It cuts the rivet heads off like butter. After cutting off the heads, I’d swap out the chisel bit for a punch bit and knock out the rivet. Easy peasy. Wear headphones and apologize to the neighbors afterwards.
Yeah, air chisels work great but like you say...it's loud.
I rebuilt my turn signal switch.
Richard2112 is offline
Old 12-16-2017, 08:58 AM   #6077
CG
BlahBlahBlah
I haven't even started my truck up for a week or three. Got a notice that the license tabs are due January 1st. Maybe Ill take it for a spin and get my new tabs (some of you call em tags). One hundred and six bucks to the state.
CG is offline
Old 12-17-2017, 04:25 PM   #6078
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sounds like a plan. As tempting as it is, I'm leaning toward keeping the frame rivets. I have to add a bolt though. GM missed one on a front bracket for the rear leaf springs.
Upper Ball Joints: Happy to say all the holes for the upper ball joints were done cleanly with a drill. I drilled through to 9/32", and the top plates to 19/164. Then I used a punch, which probably didn't do much. It was simple to remove the plate off with a pickle fork. Just traces of rivet left and simple to remove.
The holes are 3/8". A tight 3/8", but will tap easily. I figure the bolts for replacement ball joints are 3/8-16.
Lower ball Joints: I "rented" an Evertough ball joint press. As a disclosure, I don't know what the (*^ I'm doing. At any rate, I don't believe this tool works as intended, at least not for install that I can see, because the ball joint is too tall or the sleeve they provide is too tall, pick one.
However, I noticed the "pin" on the threaded rod of the tool pulls off, so I removed it. The ball joint stud then inserts into the threaded rod and will press out. Then I reinstalled the pin, and used a plate on top to remove the outer perimeter of the ball joint. It was very easy.................. Unless I'm missing something, there is no snap retainer ring with the original ball joints.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 12-17-2017, 06:16 PM   #6079
ohboy321
ohboy321's Avatar
I hooked up the battery tender today. I use my K10 as a weekend driver, but winter arrived in New Hampshire last week, the roads are covered with sand and salt, so it will sleep in the garage until April.
ohboy321 is offline
Old 12-18-2017, 10:15 PM   #6080
ghalperin
ghalperin's Avatar
The lowers just press in, the spring puts enough force on the lower arm that they'll never move.
Years ago, I did some that were a little loose in the arm. We tacked them in with the mig and never had an issue.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 12-19-2017, 11:37 AM   #6081
McToy
New to the forum , figured I introduce myself...with a few truck pics...
I have a 72 GMC truck...original longbed cut short...actually a 78 frame with a 72 3/4 ton cab but the 1/2 ton axles etc...8 inch lift kit and converted from 2x4 to 4x4
So you see, quite a Frankenstein but I love my baby :-)
Cheers,
Ralph
McToy is offline
Old 12-19-2017, 04:48 PM   #6082
3757chevy
3757chevy's Avatar
Welcome aboard ,good looking truck.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 12-19-2017, 05:12 PM   #6083
Clint72
Well, today i gained a headache.
I figured out that the m/c i just put on may be the wrong one.
I also snapped my right rear bleeder valve.
All of this, after completely rebuilding my front brake system, and changing all brake lines.
Was really hoping to not have to rebuild the rear brakes yet.
Oh well, old truck problems.
Clint72 is offline
Old 12-19-2017, 05:17 PM   #6084
Barnfind46
Barnfind46's Avatar
Repeat after me! Old trucks are fun! Old trucks are fun! Old trucks are fun!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline
Old 12-20-2017, 12:38 AM   #6085
Metaldoc
Metaldoc's Avatar
Originally Posted by 427Carl View Post
air ? oh ya I forgot . Texas is warm .
I just put snownmobile electric hand warmers on my blower. Canadian living eh. The hulk is ready for more snow.
Metaldoc is offline
Old 12-21-2017, 05:19 PM   #6086
el_fantasma
el_fantasma's Avatar
P01s, going old school! When I get ambitious I'll paint/powder coat the wheels white so they really pop.
72 White Cheyenne, The Ghost
el_fantasma is offline
Old 12-21-2017, 06:50 PM   #6087
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Nothing wrong with P01's..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 12-21-2017, 07:20 PM   #6088
Perpendicular
Got the floor shifter installed. These things are finicky abut the end result is worth it!
Oh, and new shoes
Perpendicular is offline
Old 12-22-2017, 12:14 PM   #6089
toolboxchev
Driving it to Work!
toolboxchev is offline
Old 12-22-2017, 02:13 PM   #6090
weq92f
weq92f's Avatar
Got the heads off. Ready for the head work and new roller cam install to begin!!!!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 12-23-2017, 01:43 AM   #6091
KQQL IT
At the body shop.
KQQL IT's Avatar
Got this done again, wanted to since I bought dad's truck back.
KQQL IT is offline
Old 12-23-2017, 03:04 AM   #6092
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
*VERY* nice ! .
? Did you do the painting or have it done ? .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 12-23-2017, 03:23 AM   #6093
KQQL IT
At the body shop.
KQQL IT's Avatar
Originally Posted by VWNate1 View Post
*VERY* nice ! .
No, I wish I had his talent. A local pinstriper did it for me. Aged it a little @pinstriping_dan on ig
KQQL IT is offline
Old 12-23-2017, 11:00 AM   #6094
VWNate1
VWNate1's Avatar
A *very* nice job there .
-Nate
Geezer
VWNate1 is offline
Old 12-23-2017, 03:49 PM   #6095
SKT
SKT's Avatar
Looks great!
SKT is offline
Old 12-23-2017, 06:19 PM   #6096
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Installed the pusher bumper and 4 new rear tires!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 12-23-2017, 08:42 PM   #6097
Drummerboy
Drummerboy's Avatar
Power disc brakes, rebuilt rear drums, all bew brake lines, rebuilt front end, new spindles, ball joints, tie rod ends, etc....
Drummerboy is offline
Old 12-23-2017, 10:20 PM   #6098
OregonNed
OregonNed's Avatar
I pat mine on the rear every time I walk by
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 12-23-2017, 10:33 PM   #6099
3757chevy
3757chevy's Avatar
Nice rear .
MIKE
Old 12-24-2017, 01:03 AM   #6100
mud.man.rj
mud.man.rj's Avatar
That rear is an artistic shot, looks like a painting.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Closed Thread
