Old 12-19-2017, 04:24 PM   #1
midnightrider78
midnightrider78's Avatar
Question Correctly wiring electric choke?
Carb on my '72 C20 w/402 needs gone thru as of a couple days ago.
I am in a bit of a jam with the truck outside, miles from my garage and the weather being what it is this time of year in Iowa. It's supposed to get significantly colder and probably snow by the end of the week.
I found a really good deal on a rebuilt Qjet that is supposed to be identical except that it has an electric choke. It should be here tomorrow.
The tech I spoke to said I could hook the choke wire to the coil temporarily, just to get it home.
My question is: What is the appropriate, permanent way to connect this?
Someday I will rebuild the original carb, but I have other things that are more important to deal with in the immediate future.
midnightrider78 is offline   Reply With Quote
Old 12-19-2017, 04:37 PM   #2
harpo231
harpo231's Avatar
Re: Correctly wiring electric choke?
Off unfused ign on fuse block
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-19-2017, 05:12 PM   #3
wilkin250r
wilkin250r's Avatar
Is the electric choke on the Qjet similar to the Edelbrock?
I can explain the Edelbrock electric chokes. They have a coiled bi-metal spring inside, when you apply electricity, the spring will heat up (slowly) and uncoil (slowly). It is powered by a switched power source (only on when the key is on, NOT a constant power source)
Since it happens slowly, the theory is that when you first get in and turn your key to start your car, the spring inside the choke is cold, and the choke is closed. When the car starts running, power begins to flow through the spring inside the choke, warming it up, the spring uncoils, and the choke opens up. It is designed to open up at roughly the same rate the engine warms up and no longer needs the choke. Electricity continues to flow through the spring the entire time the engine is running, keeping the spring warm and the choke open.
I believe the Qjet works the same way. So really, all you need is ANY power source that is on only when the ignition key is on.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 12-19-2017, 08:40 PM   #4
midnightrider78
Yes, I believe it is the same.
Old 12-19-2017, 08:43 PM   #5
midnightrider78
have most of a roll of 14 ga wire already. Is that too heavy?
Old 12-20-2017, 01:40 AM   #6
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
No such thing. You'll be fine with 14.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
