Never Ending Projects
Re: Spring hanger/shackle pins
Moving this to the suspension area, hopefully someone will have an answer
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Jan 2002
ive heated up the bolt heads & use a big impact wrench & try to unscrew them ?? if your bushings get screwed up -go to a spring shop & replace bushing & new grd 8 bolts -should be available at local hardware -i use a good grade_ self locking -flange nut
