#26 |
Moderator
![]() Join Date: May 2007
Re: California K20 emission question
No rosette rivets? The dmv will rake you over the coals and then bend you over. Be prepared to pay a LOT of fines, fees, taxes, etc.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#27 | |
Yes they did use rosettes. When he rebuilt and painted the truck he used different rivets. Nobody contested that. Like I said it made into my garage and the idiots in DMV sac town never seen the truck. Just hoping the GM letter will avoid the emissions issue and just get the vin verified.
#28 |
![]() Join Date: Feb 2002
GMC VINs are different.
C = Conventional [2wd] E = V8 1 = 1/2 Ton 34 = Fleetside [-] = Dash means no Pennsylvania state certification [GMC only] 1 = Oshawa assembly Z = 1970 50609 = Production sequence. So the VIN tag on your 3/4 ton is for a C/1500 not a C/2500. It's a Canadian-made Oshawa truck from 1970, not a '71 Fremont [Z] truck. If there is a VIN on the engine block, it's not from a truck. If the block VIN matches the number on the plate, that's a little TOO coincidental. Of course I'm a long way from Canada, so my experience is limited. Can't say why there's no ''9'' code in the VIN. Bruceman1968 is the resident VIN puzzle expert. Maybe he'll show up.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-22-2017 at 02:51 AM. |
#29 |
![]() Join Date: Oct 2009
GMC VINs always puzzle me, ha - but since you mentioned Bruceman's charts, now I'm really curious, because that's where I got my info - seems a 70 should start with C9E140? But clearly the VIN in the pic is Canadian and your decode makes sense - where did you find the Pennsylvania info, etc? I just thought GMC had to have a 9 in it as the 2nd digit for pre-72s?? Thanks.
last pic of this post http://67-72chevytrucks.com/vboard/s...05&postcount=1 |
#30 |
I understand not having the rosette rivets may be an issue. Question. What do those who repaint their trucks do? They remove vin plates. Do they put them back using same rivet type?
The vin on plate does match vin on title. BUT! Always a butt. Though not a huge deal. Canada messed up on the vin. Paperwork. They mistook "Z" for a "5". Thats what i feel was the red flag. The vin verify paperwork sent in corrected that but I feel it may have pushed to further confirm. Heres the thing. From import to chp inspection during import no flags were raised we had all the paperwork. Cali. DMV has deciding to make things difficult. Can only ride the lightning from here. Here is the first thread I created when coming here. Take a read. And Bruceman is a huge help. http://67-72chevytrucks.com/vboard/s...d.php?t=742237 |
#31 |
Carpe manana
![]() ![]() Join Date: Dec 2010
On my builds we taped off the VIN plate and paint around them.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#32 |
Moderator
I’ve done that on all my builds and so does every body shop that I’m aware of.
#33 |
Whoops. I guess my Father in Law made a huge mistake and we may pay dearly for it. Its already been a rollercoaster in hell. After a while you stop feeling the burn. lol
I pray we get through this with the truck. We just want to preserve the hard earned money and time he put into this truck and represent it at shows and drive it in Sundays. He did so much to it. Got it ready and done with. Never got to drive it. He stored it in a garage for 10 12 years. |
#34 |
![]() Join Date: Jan 2002
I registered my 72 K10 in California (from Washington state) and my 75 Jeep CJ5 (Nevada) with no issues and no emission equipment inspection on either. The DMV I dealt with wouldn't know the difference between a rosette rivet and regular one. (That was also my experience in Oregon where I had to show the kid where the VIN plate was.) Coming from Canada is probably what tripped the DMV to look harder or you just had the bad luck of going to a DMV location where the register was not comfortable with a Canadian import.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
#35 |
That's a tiny little detail that might have been more helpful somewhere around post #1.
![]() Last edited by jocko; 12-23-2017 at 12:01 AM. |
#36 |
Carpe manana
Example pic of a CA replacement VIN
#37 |
Carpe manana
Take a look at this GM windshield decal.
Could it be that GM affixed these after the test for the trucks that were exempt from the AIR equipment but underwent the RPO YF5 emissions test? Looks like original Soft Ray glass. From a sort of survivor until recently one family owned BB C20 on eBay (love that two tone): https://www.ebay.com/itm/1972-Chevro...QAAOSwHflftFrx
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-17-2020 at 09:28 PM. Reason: Added |
#38 |
Carpe manana
Looks like other vehicles used the same. Here’s a reproduction example for a Camaro
#39 | |
![]() Join Date: Nov 2018
In Kalifornia any vehicle up to 1965 is a free for all.. do as you please no smog specs even exist prior to 1966. In Kalifornia any vehicle from 1966 to 1975 are not currently called in or given a semi-annual smog test. Most call that smog exempt it actually is not true. In Kalifornia should your vehicle ever end up in front of Air Resources Board aka/Smog Referee, however referenced CHP, DMV etc and your vehicle falls into 1966-1975 year range. You are required to have every piece of smog equipment that it was manufactured with intact and operating to pass smog for the vehicles year requirements. Smog equipment and the results that were acceptable varied from 66-75. And believe me these guys at ARB like to split atoms....I actually think they get off on it. |
#40 |
[QUOTE=DeadheadNM;8837248]Take a look at this GM windshield decal.
Could it be that GM affixed these after the test for the trucks that were exempt from the AIR equipment but underwent the RPO YF5 emissions test? Looks like original Soft Ray glass. No actually the CHP used to set up sites and would randomly pull vehicles in and check things like turn signals, brake lights, head lights, horn, wipers etc That was more of a road worthy safety sticker, if you already had one on the windshield they flagged you on thru. |
#41 |
Carpe manana
I’m pointing out the GM decal not the CHP decal but that’s interesting to know.
#42 |
![]() Join Date: Jun 2018
I'm not sure where this thread is going, but if anyone has questions regarding what emissions equipment were installed for various models years the service manuals should have a small section dedicated to it. For '71, PCV and C.C.S. were the only "installed" emissions equipment for 20 and 30 series trucks. Evaporative Control System (the tank and fuel bowl vent tubes to charcoal canister) are only for series 10.
1971 Pontiac Firebird 1971 GMC C2500 |
#43 |
Smog pumps or A.I.R's were first required in Kalifornia in 1967 and they ran till about 1975 or so when the Catalytic Converters were introduced.
Different trucks/cars had different rules e.g. C10, C20, C30 also different engine sizes entered into the equation also so it's a twisted tale to get it all straight in your head for sure if that's even possible. Rumor has it too (and I could be 180 out) that the 402's we find in our trucks from the factory was a GM smog game, seems 400 Cu. In. and below was the cutoff for anything smog related such as compression etc. The 402 Cu. In. put them above that threshold. |
#44 | |
Vin plates can be removed and replaced on the same vehicle example either doing a restoration or replacing a door post because of an accident . We did it at the body shop for older and newer cars. Newer cars were for dash replacements. The documents and inspections from DMV and State Police must be retained with the vehicle. ." While I am fixing up an old car, am I allowed to restore a damaged VIN stamp? Yes. Vehicle Code section 10750 specifically allows registered owners to refurbish the original identification number of a vehicle or part. However, the law also states that you must first receive the permission of the DMV. If you have questions on how to do this, you should speak with an attorney who is familiar with how to request the DMV’s permission to restore a VIN stamp" https://www.wklaw.com/practice-areas...803-and-10750/
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
