Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-23-2017, 01:02 AM   #9
DoctorGlenn
Re: 1956 GMC F370/374 LCF Brake Upgrades
Okay, it's been a while and between work and winter finally deciding to arrive things are moving slowly on the truck. I picked up a wrecked 2012 NPR-HD a couple of weeks ago for what I thought was a bargain price and a semi-local truck salvage company is pulling the parts I want in exchange for the rest of the truck that I don't need.
I'm getting both front and rear axles, all of the steering and all of the brakes. For the brakes that will give me front discs, dual circuit master cylinder, and the vacuum booster. I'll also be able to replace the steering gear/slave cylinder setup on the truck now with modern power steering as well as get more reasonable rear end gearing (5.38:1 rather than the 6.61:1 high range it has currently).
I should be getting the parts in a couple weeks (the shop shut down for the end of the year) and I'll post more when that happens.
DoctorGlenn is offline   Reply With Quote
