Old 04-22-2004, 12:36 AM   #1
ocbaud
Garage Queen Material
brake vacuum line on carb???
where does the vacuum line for the brake booster hook up on holley/demon carbs?
i believe the speed demon i am gonna get has 3 vacuum ports.
1 for pvc
1 for manifold vacuum
1 for ported vacuum.
ocbaud is offline   Reply With Quote
Old 04-22-2004, 01:45 AM   #2
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
Usually, these carbs require that you run a "T" fitting, where your modulator valve line connects to the manifold. You will source your brake booster vacuum from there.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 04-22-2004, 01:46 AM   #3
ocbaud
i already have the "t" fitting in there.
thats something else i was wondering about. how am i gonna be able to run that with the carb being so much longer than stock? wont it hit it?
Old 04-22-2004, 02:08 AM   #4
Destructo
My friends demon extends over the rear vacuum port on his edelbrock performer, we just put a plug in it and ran his brakes off the carb, its probably not the best option, but so far it works, I think it should be coming off the manifold though, you get better signal that way. We put a vacuum resevoir on his to help the brakes out a bit too, but hes only running a xe262.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 04-22-2004, 06:11 AM   #5
TwinTurbo
TwinTurbo's Avatar
wherever you connect it, make sure you connect it to a port that sees full manifold pressure (since it's pressure lower than atmospheric, not a real vacuum), not venturi vacuum.
TwinTurbo is offline   Reply With Quote
Old 04-22-2004, 08:20 AM   #6
76bonanza
76bonanza's Avatar
If you run a spacer under the carb will it raise it enuf to go over the vac fitings?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 04-22-2004, 09:22 AM   #7
Destructo
I would think a 1" spacer should clear a short fitting, may have to cut some threads off to get it lower in the manifold. We can't put a spacer on my friends camaro because with the torker II it had before the performer and a adapter it would crunch a 2" tall air filter. But with OCbauds truck he should have plenty of clearance, i'm running a medium rise intake with a 4" tall filter and think I could run as much as a 6" filter.
Old 04-22-2004, 10:11 AM   #8
76bonanza
76bonanza's Avatar
How much longer is the demon than a regular holley?
I have a hollry now but plan on a road demon soon. just curious.
1968 c10
lowered 3" 4"
Old 04-22-2004, 02:40 PM   #9
Destructo
The fuel bowls are slightly longer I think, do you have the 4160 holley? If so I would guess maybe 1/2-1" longer on each end. No gurantees on that though.
Old 04-22-2004, 04:30 PM   #10
Jonboy
Slots go on anything!
Doesn't the brake booster fitting screw into the bottom of the carb base on the Q-jet?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-22-2004, 04:40 PM   #11
Destructo
Yeah, I believe so, mine is going straight to the manifold port though with nothing else tapping off of it. The port on my Q-Jet is just blocked off.
Old 04-22-2004, 05:31 PM   #12
ocbaud
is the stock fitting for the brake booster the same size as the intake port?
also, i think i will only have to have the following hooked up:
full:
brake booster
tranny
heater vent thing
dizzy
pcv
nothing on ported.
is the pcv a different port? how am i gonna beable to hook all of those up if i only have the 2 ports on the carb?
Old 04-22-2004, 09:32 PM   #13
76HighSierra
full:
brake booster
tranny
heater vent thing
dizzy
pcv
nothing on ported.
Nope, the carb fitting is 1/4" NPT, while the intake fitting is 3/8" NPT. Hook your brakes, tranny and heater vent thingy up to the intake manifold fitting and the PCV to the large front port on the carb and the dizzy vacuum up to the timed port on the carb.
Marc Bona
Hobbs, New Mexico
3.40 rear.
