Old 12-26-2017, 08:44 AM   #1
Beatrice
Beatrice's Avatar
opinions on updated chassis wiring?
what's everyone upgrading to when it comes to chassis wiring? i've been looking at the american autowire. any opionions on this kit or any others i should look at.
Beatrice is offline   Reply With Quote
Old 12-26-2017, 10:01 AM   #2
raidmagic
raidmagic's Avatar
Re: opinions on updated chassis wiring?
I've done 4 different cars with Rebel harnesses and plan on doing this truck with one too.
raidmagic is offline   Reply With Quote
Old 12-26-2017, 11:11 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
American Autowire is good. I use Ron Francis on all of my hot rod projects, including my C10 that I'm currently wiring. It comes pretty custom and pre-wired according to the application and user specified options. Each kit comes with an individual serial number, so customer service is specific to the kit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-26-2017, 11:31 AM   #4
Clyde65
Clyde65's Avatar
American autowire is who I use. I have used some that were much cheaper but imo, cheaper isn’t always better.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-26-2017, 07:28 PM   #5
Heater63
Heater63's Avatar
I used AA, Classic Upgrade kit. Very pleased, made it easy for added AC, power windows, fan, HEI, third brake, rear gas, custom gauges, and more...
292 + TKO500
Heater63 is offline   Reply With Quote
Old 12-26-2017, 10:05 PM   #6
mehoff400
does American auto wire come with all new pugs and such or is it just a new fuse block and wiring like kwik kit?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 12-27-2017, 07:04 AM   #7
Beatrice
Beatrice's Avatar
American autowire come with new plugs. even comes with dew dimmer switch, headlight switch and a few other pcs which saves money elsewhere. I looked around a bunch last night and pretty sure that's what i'm going with. i'm going to call and see if theres enough room in their relay/fuse panel to make my standalone ls harness go straight to it
Old 12-28-2017, 09:10 AM   #8
bj383ss
bj383ss's Avatar
I used the AAW kit. It comes with damn near everything you need but you will need to buy or rent the crimping pliers. I got a pair off of Amazon for $40 that worked great.
20150508_152019 by bjohnson388, on Flickr
20150606_091422 by bjohnson388, on Flickr
20150510_153700 by bjohnson388, on Flickr
20150517_113055 by bjohnson388, on Flickr
These crimpers allow you to make the factory style crimps
20150517_161447 by bjohnson388, on Flickr
One more thing here is the firewall diagram that shows where all the wires come through factory. Made by Member Racecougar.
received_1085674448116427 by bjohnson388, on Flickr
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-28-2017, 09:15 AM   #9
Beatrice
Beatrice's Avatar
bj383ss
is there extra spots for relays/fuses in that kit? I need some extra spots for my engine harness wiring. I emailed AAW but no response yet. Either way I'm going that route for sure looks like the best kit out
Old 12-28-2017, 09:32 AM   #10
bj383ss
bj383ss's Avatar
I just took this shot. There are extra places to plug in for ignition and battery sourced power. I don't know how many fuses you need. You could use the CB spot for something and the power seat plug if you not using that I suppose. There is also the fused spot with the number above it I think that is for an auxiliary harness or fuse block they sell can't remember.
20171228_072246 by bjohnson388, on Flickr
Bret
Old 12-28-2017, 09:34 AM   #11
Beatrice
Beatrice's Avatar
yeah looks like there are enough there thank you for that.
