![]() Join Date: Nov 2002
Move V8 to V8 location?
My 350 is mounted in the I6 location. What is required to move it forward to the "real" V8 location? I've seen this mentioned before, but can't find it.
I tried a search on the board and came up negative. Thanks.
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
![]() ![]() Join Date: Jul 2002
Moving isn't too bad just unbolt and slide everything forward. However, if you are running a stick, you'llneed to redo the shift (column) and clutch linkage. Automatic you'll probaly need different shift linkages. Not sure, but you may need a different throttle linkage rod. The biggie will be redoing your driveshaft for the additional length. I haven't dealt with the two piece drive shafts much, and seeing yours is a long bed I am assuming that is hat you have. You might be able to get by just swapping the front shaft.
![]() Join Date: Aug 2001
![]() THAT SOUNDS LIKE AN AWFUL LOT OF WORK FOR ABSOLUTLEY NO GAIN. MAYBE I JUST DON'T UNDERSTAND THE BENEFITS. COULD SOMEONE ENLIGHTEN ME??? I'VE BEEN INSTALLING V-8s IN THE INLINE SIX LOCATION FOR YEARS. ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
tight fit
Its a little tight trying to work around the distributor area. It would also put my fan blades into the shroud instead of 2" away from the shroud. Also, I tend to think that if GM designed the V8 to sit 2" forward there must be a good engineering reason why. Corporation do not spend extra money for little or no benefit.
Those are the reasons I'm thinking about it. Doesn't mean I'll change it any time soon - have some steering and rust issues to try and fix first. It may well be there is no compelling reason for me to go to the trouble of moving it forward -
its all about the +6 inches
You may have to re-do some of your exhaust too...the tranny crosmember will be moved forward, and you may have pipes there.
Fabricate till you "puke"
I agree with junkyard John on the sb in I 6 position. the dist does fit a little tight,which some guys dont like. as far as the space issues on the fan /radiator, you can opt for the waterpump, pullies, & accessories from a 73 up truck to help the problem. Also , you willl need the radiator hoses, & if you still have the curved neck in the lower radaitor, you will need to swap it to use the later hoses. good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Formerly yellow72custom
Welcome back crazy longhorn.....been awhile since i've seen you around!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Thanks for the welcome.....I have been off line for a while, but have had lots of time for wrenches & fab on the old chev. Im back to work in the muffler shop, so ia have beeen keeping fairly busy. Its good to see some "familiar faces"
![]() HMMMMMM ...... I KINDA LIKE THE WEIGHT TRANSFER , & THE ADDED TRACTION OF SMALL BLOCKS IN THE 6 CYL. POSITION. THE HEI DIST. IS A LITTLE TIGHT BUT NOT UNWORKABLE. AFTER WORKING ON G.M. VEHICALS MOST ALL OF MY LIFE, I CAN'T SAY THAT ALL G.M.s DESIGN OR ENGINEERING IDEAS ARE THE SMARTEST, OR DESIGNED WITH MY WELL BEING & EASE OF WRENCHING ON THESE VEHICALS BEING TOP PRIORITY. WERE ALSO TALKING ABOUT 37 YEAR OLD TECHNOLOGY. ![]() ![]() ![]()
Careful there John.....we will get some of the "resto nuts" revved up! I Like the weight transfer also, & have modified many things to get it
Good Points
Always appreciate the views on this board. Always learn something or have a chance to see things from a different perspective.
I thought about the weight too. It seems to me that the V8 position creates a longer forward of CG moment arm and that the I6 position is therefore more stable, so I agree with that. I don't fool around in the HEI distributor area much, so the tight space there hasn't been a problem - although I tried to reroute the tach wires last week. PO had them going through the "vacum gauge" hole and up the outside of the bezel. I routed 'em up under the steering column groumet area instead. I could not easily reach the green wire going to the distributor due to the tight space, so I finally cut it in the cab and soldered it back together once I had the rerouting done. That got me to thinking about putting the engine up in the V8 spot. Since its a lot of small changes to make it work - like reworking the shifter, the accelerator linkage, and lengthening the drive shaft, I think its best to leave it alone and work at fixing all the goofy things the PO did, getting the overly sensitive power steering sorted out, getting power brakes, THEN attacking the rust I'm finding in my kick panels, floor edges, rocker panels, right inner fender, and radiator support structure (under the battery tray on those two). Thanks for the inputs. Just wanted to make sure I wasn't doing something wrong leaving it there.
my opinion only, it feels the space and just looks better in the v8 position. i did the i6 to v8 swap and spent the extra $ putting mine in the v8 position.
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
Would the drive shaft be the same my 69 had a I-6 and 3 speed and I am installing a 327/TH 350 IF I kept it in the 6 cyl. posistion?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Kaycee, if you have a short 350 turbo (6" tailshaft), it should be a direct bolt in. ......crazyL
#15 |
OK thanks alot
#16 |
Speaking of driveshafts, I have a 68 gmc/lwb with a v6 with the manual 3-speed in the v8 position with an upcoming 350/th350 swap? Will i need to lengthen or shorten my front driveshaft?
thanks! |
#17 |
Remember that it's perfectly accurate to replace the phrase "inline 6 position" with "4wd V8 position."
True, GM engineered the engine to be a couple inches further forward in 2wds, but they also obviously believed (and have been proven right) that the other position was also acceptable. Brian |
#18 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Personally if it were me and it's already in place with no issues I'd leave it. You'd gain no more by moving it forward than you would by moving it back if it were in the "correct" position.
![]() Weight transfer, headers = hp gains pffft. Maybe if you're racing or doing a HP buildup. but to go to the Home Depot to get lumber or make dump runs, don't think so. CrazyL, long time no see ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#19 |
I just had to move my whole engine forward from the I6 position, In the past with standard heads it really wasn't an issue, using roller rockers on stock heads where you need taller valve covers creates a little issue. Also the real reason I had to move it forward was because of the aftermarket heads I am using are a raised runner and where hitting the firewall. Getting to the Fuel Injection fuel lines was also a real pain in the a$$. Otherwise if things are all working and unless there is a specific reason I wouldn't move the engine to the V8 location because there is where it was supposed to be. JMO
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
#20 |
Some one has said here in the past, that a later long water pump should put the fa into your shroud...that, or a 4X4 small block shroud would do it for sure.
Just remember if you try the long pump, you'll need new brackets for all the stuff and pullies and rewire the alt to the other side of the engine and all kinds of crap. |
#21 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
...or... you can use a 9 inch tailshaft TH350 (or a 700R4) and put the engine in the V8 position, AND still use the stock driveshaft. The V8 position moves everything forward 3 inches and the longer (6 vs. 9 inch ) transmission tailshaft compensates.
#22 | |
Re: Good Points
#23 |
Not a mech...
No, a former naval officer (ship drivers use the same terms), retired naval aviator (10 yrs active, 12 in the reserves), and current American Airlines Captain.
I just play mechanic on the Truck ![]()
#24 |
I recognized the CG term from my dad...I guess pilots use the term too, all his pilot buddys are always talkin CG this stop leaning forward, you're messin up the CG... blah blah blah.
