Old 12-28-2017, 05:56 PM   #1
LVPhotos
LVPhotos's Avatar
Rockers body line.
While messing around I started looking at the rockers on the '62. Held up a replacement to see where to cut. Low and behold there is a body line. Is this on knee knocker cabs? The replacements don't have this speed bump. Not rusty but damaged over the years.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-28-2017, 06:04 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Rockers body line.
Looking at its a jack FUBAR! When? The side pipes hid it for years
Old 12-29-2017, 08:22 AM   #3
oldusafmsgt
oldusafmsgt's Avatar
All 60-66 rocker panels are identical. You'll discover aftermarket/reproduction panels are not always exact reproductions of originals.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 12-29-2017, 10:52 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I have two aftermarket cab corner patch panels. The Triplus brand has nice defined contours similar to the original. The Counterpart brand is very under shaped.
The stores that sell either will tell you they are all the same. Some will only sell Triplus because of the superior shaping.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-29-2017, 01:35 PM   #5
yeah_yeah_na
Related to this, probably discussed on here at some point. Who supplies the best sheet metal parts?
yeah_yeah_na is offline   Reply With Quote
Old 12-29-2017, 02:17 PM   #6
LVPhotos
LVPhotos's Avatar
I got the OER ones. Suppose to be top notch, maybe other gm approved but for our trucks it just more money for box
I checked, the parts themselves are Tri plus
Old 12-30-2017, 01:29 PM   #7
yeah_yeah_na
Thanks for that, I've fitted a set of OEM fenders to a 68 Camaro once, one went on like a square peg in a round hole, I thought it was maybe an issue with the car from a previous repair, turns out maybe it wasn't?
I guess before I buy my rockers for my truck I'll do a little shopping, thanks for the warning.
Old 12-30-2017, 01:52 PM   #8
oldusafmsgt
ALL reproduction sheet metal comes from China. Their quality control is sporadic, and is hit and miss. Tri Plus and the others are importers/distributors, they manufacture nothing.
Old 12-31-2017, 01:20 AM   #9
LostMy65
LostMy65's Avatar
Maybe Triplus sends back to China everything that doesn't meet their quality standards.
However they do it, Triplus puts their sticker on the nicely shaped patch panels, and counterpart puts their sticker on the poorly shaped pieces.
Old 12-31-2017, 01:27 AM   #10
dracko
dracko's Avatar
I would totally agree with this statement based on rocker panels and cab corners I’ve used, but have to give props to Counterpart for the bedsides and tailgate I got from Brothers trucks. They are really nice looking reproductions.
dracko is offline   Reply With Quote
Old 12-31-2017, 01:42 AM   #11
LostMy65
LostMy65's Avatar
That's actually good to hear.
Old 12-31-2017, 06:45 AM   #12
oldusafmsgt
If you check the UPC code that’s on every part, you’ll see it has a country of origin code. And that country of origin code is China, every part. If you email or call Tri Plus or any other distributor, they will tell you they import all sheet metal.
Old 12-31-2017, 11:39 AM   #13
63frankintruck
So what to do? (where are we supposed to get repo rockers that are even close to fitting) I purchased a pair for my 63 and they were not even close.
Knowing now what I did not then- I should have just cut out the portions of damage and made my own patches or carved up the replacements rockers to patch my damage.
As it stands now, I totally removed both rockers by drilling out spot welds ( now I cant find anything that will fit decent)
63frankintruck is offline   Reply With Quote
Old 12-31-2017, 12:42 PM   #14
rvrfoot
I got a complete bed, fenders,doors no problem.
rvrfoot is offline   Reply With Quote
Old 12-31-2017, 12:51 PM   #15
dracko
dracko's Avatar
Like mentioned earlier in the thread, try to a set of TriPlus or Goodmark labeled rockers. They’ll probably need some reshaping where they meet the A pillar but other than that should fit decent.
What’s wrong with the ones you have exactly? Any pics?
Old 12-31-2017, 01:00 PM   #16
nsb29
nsb29's Avatar
I got rocker panels and front fenders from LMC truck The fit was fair I believe most of the problem is the metal they're made from the original parts were made from 16 gauge and was softer the new stuff is thiner but is stiffer and after stamping it springs back especially with the rocker panels I believe even if you had a set of original rockers you would have to do some massaging to get them to fit properly some of the companies handle the seconds and thirds as a rule I think LMC trucks do not carry the firsts if I were to do it again I would try try plus
nsb29 is offline   Reply With Quote
