#176 |
1960 GMC Burb
Re: 1960 GMC Suburban
Thanks to MusicMan70 for the comparison and picture below. Gave me the info I was looking for:
( Sodly also said he has used these on two of his and likes them) (MusicMan70) Here is my 61 with the Yokohama's on 15 x 5 wheels. I felt they rode fine on stock suspension and shocks with only lowering blocks (2") and torsion bars slightly turned down. Prior to this I had 235 x 70 x 16's and those rode nicely too, but I used spacers for late model truck wheels. I tried 215 x 75 x 15's but they were too short. I wanted the skinny tire factory look. Here are some tire compare pics
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() |
#177 |
Looks good man. You're making great progress. No matter how small moving forward is moving forward! Keep it up!
#178 |
Any updates?
"There are seven days in a week. Someday isn't one of them." http://67-72chevytrucks.com/vboard/s...d.php?t=686078 |
#179 |
1960 GMC Burb
Unfortunately no. No activity. That's the way it has been. Between finances, weather and time. None of them match up. Still hoping something will happen. Built a paint tent and before it could be used, an unexpected storm came through and destroyed it.
Still trying. Will never give up. Just wish I could get her done while my Dad is still healthy enough to enjoy her.
#180 | |
#181 |
1960 GMC Burb
Well, although I have said it before, this time it looks like things will start to roll again on the Burb. My father decided that he wanted to see the Burb back on the road again and wants to help financially.
I have to start over again trying to locate the best deal on the best parts to get things done. Right now I have been trying to find somebody just to shoot (finish) the paint. I will be asking for info on best places and deals on parts etc since all my original research and lists are from 4 years ago. Have to update my catalogs since they are all 4 + years old.
#182 |
1960 GMC Burb
So anybody have a hidden site that has good, but reasonable radiators for my 60 V-6 Burb ? The local shop want $500 just clean, rod an solder/braze a leak on the top of the original. Replacements are 389 - 420+ and that price makes me think that I should go with the $500 to keep it original..thoughts ??
#183 |
1960 GMC Burb
Since this project is now back on the road and hopefully all the way to the finish line, I need two important items ASAP.
Which full electrical harness for the 60 Burb is recommended ? I want to buy a complete replacement. Also, at this point, which supplier has the best fitting side glass window rubber ? I have a local company that will cut the glass unless somebody knows a supplier that might be cheaper. The Burb is finally going to paint and I need to pull all the glass. I have a company ready to install new glass but they even said I should look for a good supplier of the rubber. Any leads on original style upholstery would be appreciated. I know there was a place up in Oregon or Washington State that had it, but I haven't located the place yet. Excited to get this starting to roll again. Installed the new radiator, cleaned and tightened up the the water circuit with all new hoses, gaskets etc. Finishing up the carb rebuild and the gas system with my temp tank will be completed too. As always, any & all suggestions and comments welcome. Not worried about haters here since this isn't a Ford forum ![]()
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() Last edited by KIC; 12-30-2017 at 10:29 PM. |
#184 |
![]() Join Date: Jul 2016
20 or so years ago i had local glass guy replace the rubber on my side windows, he used some generic rubber weatherstripping off the roll. if i recall correct there were a few choices of which generic weatherstrip profile to use. i went for the thinnest, because it was the cheapest. they have held up well except for coming unglued at the corners. I had some extra cash a few years ago and bought a expensive correct set from steele rubber. i havent put them on yet, but they definitely will look a lot better then the skinny home made stuff i have now.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
#185 | |
![]() Join Date: Nov 2012
https://www.steelerubber.com/search?...-sport-utility Sanders Reproduction Glass makes all the glass and their patterns are right-on. https://www.sandersreproglass.com/orderonline.php |
#186 |
Rollin' Old Skool
This is the place you're thinking about regarding original-style upholstery. I've never used them & have read mixed reviews, not about quality but customer service.
https://smsautofabrics.com/
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) Last edited by likaroc13; 12-31-2017 at 01:16 PM. |
#187 | |
#188 |
1960 GMC Burb
So we got somewhere today. Got the water system all tight and ready with new radiator, thermostat and hoses.. The same with the temp gas system using a boat gas tank. The battery in and cables replaced. New fan belt.
pulled the plugs and let a little Marvel Mystery Oil soak in each cylinder. replaced plugs and rocked it back and forth. Turned the key......She fired right up ![]()
#189 |
![]() Join Date: Feb 2011
Awesome to hear another GMC V-6 running again!
KIC, what is the part number you used for the upper radiator hose?
MusicMan70 1961 GMC Suburban |
#190 | |
1960 GMC Burb
The top shows: Day 70344 The Bottom was Day 72033
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() Last edited by KIC; 01-29-2018 at 09:11 PM. |
#191 |
Thank you for this information along with the other part number KIC!
#192 |
1960 GMC Burb
I should say that the aftermarket radiator had a different size nipple, or "bung" as I have been told recently on the bottom, The hos I got for the bottom needed the small inside diameter on the radiator side
Here is the link to the thread where I talked about it.: http://67-72chevytrucks.com/vboard/s...d.php?t=748899
#193 |
1960 GMC Burb
I posted this in the main section, but thought I would post it her too:
My 60 305 appeared to have a fuel pump issue. Bought a new manual pump and it wouldn't work either. Kept chasing and checking for line leaks etc. Even checked with a vacuum tester which appeared to show it sucking but still not pushing through. Finally decided to bench test the new one with a bottle of gas and it worked fine. Then I bench tested the old one and it worked fine. Started to think that the issue was inside where the pump lever rides on the lobe (?), but then remembered that the vacuum test appeared to show it creating a vacuum. SO...... Any ideas ? I really want to stay with the original manual style, but even thinking of running a hidden electric through the manual one..
#194 |
1960 GMC Burb
It is weird, we even bypassed the whole line with short line to a bottle with gas in it.
I did run into a friend that has a restoration repair shop and he told me that he has had up to 5 failures in a row on new manual pumps. And he buys top end pumps. He said that he finds very small shavings and particles in the pumps that can affect the valves inside. So he buys a pump and immediately takes it apart and cleans it. That will probably be my next move followed by an electric pump that flows through the mechanical so it at at least looks original.
#195 |
KIC, I have had several fails with NOS mechanical pumps as well as "new" pumps bought from NAPA etc. I think they sit on the shelves so long the diaphragm's (?) wear out or so I've been told.
So I finally did go with a Carter electric (P4070 4-8psi), but did not run it through the old mechanical because I was told it would fill the oil pan with gas (it Did). My mechanical is still there but my fuel line just goes around it. I guess you could hollow it out and run the line through there for looks (I think that's what you meant)
#196 |
1960 GMC Burb
Hi All
I have an important question. I am in the process of returning my 60 Burb back to a 3-on the tree. Many years ago my older brother blew up the original drag racing his girlfriend in reverse...( don't ask ![]() I long while back I had obtained a good 3 speed from a member who was putting in a 350 with auto. Below are the two different bell housings that have different bolt holes although they both work/fit. Is the first one with the little cover on the rear top the correct one for the 60 Burb 3-speed ? It has been a hassle finding the correct clutch and parts, but looking forward to making it back to original .
#197 |
1960 GMC Burb
The top one is what came with the 3-speed, but I do not recall what engine the person had that he pulled out of his Burb.
The bottom one could very well be the original from my Burb and we might have just installed the 4-speed with that bell housing.. I just can not recall since it was around 1979ish when wee did the tranny swap. I definitely want to be as original as possible..
#198 |
Yes I'd agree with the others that the bottom one is correct.
#199 |
1960 GMC Burb
Thanks guys I appreciate the input
#200 |
1960 GMC Burb
So it has been moving along..slowly but moving. We fired it up after many years and it literally purred like a kitten but it leaked like broken dike from a freeze plug. Figuring that when one leaks after 58 years, the others would soon follow.
Decided to pull the engine to replace all the freeze plugs with easy access. That led to reinstalling the original type 3-speed on the tree transmission. Which led to a new clutch and bearings..which led to a new starter, which led to a new oil pump... I mean..it was already out and taken apart.. Engine compartment cleaned and to be painted.
