Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-03-2016, 03:11 PM   #26
jocko
jocko's Avatar
Re: '63-'66 Power Brake Booster Bracket With Hydraulic Clutch Conversion
Captain, I've been absent from the 60-66 world a bit, missed your production of this kit. Beautiful work as always.
Old 12-04-2016, 12:56 AM   #27
Captainfab
60-66 Nut
Thanks for the compliments
Originally Posted by KenAdams View Post
Got mine today. You have far exceded my expectations. It looks great. I wish I could weld half as good as you!
Old 01-09-2017, 01:17 PM   #28
KenAdams
KenAdams's Avatar
I think I voided the warranty on my bracket. It's too cold to work outside so I spent an hour on the kitchen island with sandpaper smoothing the driver's side interior corner and passenger side exterior corner welds to get it ready for powder coat. Looks real good. I love sexy tig welds, but now it looks like it was carved by the gods. Said it before, but kudos to your welding ability, no undercut and good penetration.
KenAdams is offline   Reply With Quote
Old 01-10-2017, 12:06 AM   #29
Captainfab
60-66 Nut
Yes that does look good. Post another pic after you get it powder coated.
Old 01-17-2017, 07:52 PM   #30
KenAdams
KenAdams's Avatar
Back from the powdercoater. Looks good, real good.
Old 01-18-2017, 12:23 AM   #31
Captainfab
60-66 Nut
Yes that does look good........thanks for posting
Old 05-31-2017, 10:25 AM   #32
Bison
Exclamation Re: '63-'66 Power Brake Booster Bracket With Hydraulic Clutch Conversion
Hi all,
In my search for a brake booster to use with this kit, I stumbled across Tuff Stuff, who make a variety of boosters in different diameters (single and dual), plus they come in a bunch of different colours.
I emailed them to ask what the bolt pattern on the firewall side was, and got a response that included the following chart. The email also explained that the mounting studs are on a 3 3/8" square pattern.
After a quick trip to the garage with a tape measure, I'm preeetty sure these will work, but I thought I'd run it by the man himself first.
Thoughts, CaptainFab?
'64 GMC 910
Bison is offline   Reply With Quote
Old 05-31-2017, 10:30 AM   #33
Bison
I can't edit my post above for some reason, so here's the link to the boosters.
'64 GMC 910
Old 05-31-2017, 11:29 PM   #34
Captainfab
60-66 Nut
The booster hole pattern in all of my booster brackets is 3-3/8" x 3-1/2". To use a aftermarket universal booster with the 3-3/8" x 3-3/8: stud pattern, you simply need to elongate the holes slightly with a round file.
Old 06-01-2017, 05:35 AM   #35
Bison
Awesome, then that's exactly what I'm going to do!
'64 GMC 910
Old 07-30-2017, 12:37 PM   #36
Slammed96
Sent you a pm on this Captainfab
14 Silverado- 4/6 drop daily
66 GMC short wide Custom Cab- building to be low and cruise. 283/t56 swap occurring now. Stupid low static drop
55.5 Chevy 3600 NAPCO 4X4.... not sure where I'll take this one...
Slammed96 is offline   Reply With Quote
Old 07-30-2017, 01:44 PM   #37
rvrfoot
Get the bracket in raw steel. Open the holes then paint.
rvrfoot is offline   Reply With Quote
Old 07-30-2017, 11:09 PM   #38
Captainfab
60-66 Nut
I replied to your PM.
Old 10-17-2017, 11:56 PM   #39
Captainfab
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
Old 12-31-2017, 11:05 PM   #40
EagleScreech
Just got this kit and I couldn't be happier. Quick shipping and unmatched quality. Thanks CaptainFab, can't wait to get this rolling!
EagleScreech is offline   Reply With Quote
Old 01-01-2018, 12:25 AM   #41
Captainfab
60-66 Nut
Thanks for the purchase and the compliments
Old 01-01-2018, 12:36 PM   #42
sirJim
Pictures always help. 62 chevy suburban. I love this setup. only thing I had to do was add 2 washers to the block to change the angle for clearance for the large pedal spring. Keep up the great work Capt.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 01-01-2018, 11:50 PM   #43
Captainfab
60-66 Nut
Thanks for the compliments sirJim and the pics also.
Old 01-10-2018, 01:03 AM   #44
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 02-16-2018, 08:29 AM   #45
raidmagic
raidmagic's Avatar
So I get this bracket, provide my own booster and clutch cylinder? What clutch cylinder do you recommend? I have a brake booster and master cylinder from a 97 S-10. Is there anything needed down on the transmission?
raidmagic is offline   Reply With Quote
Old 02-16-2018, 08:31 AM   #46
raidmagic
raidmagic's Avatar
Also if I buy this and your power steering bracket do you combine shipping?
Old 02-17-2018, 12:06 AM   #47
Captainfab
60-66 Nut
You must provide the brake booster and master cylinder you wish to use. I typically supply the correct clutch master for your application just as described and shown in post #1. You must have some sort of slave cylinder and mounting bracket on the bellhousing to be able to take advantage of the hydraulic clutch conversion. One option is to use a '84-'91 truck bellhousing which has a factory hydraulic clutch.
Yes I always combine shipping when possible.
Old 03-16-2018, 08:13 PM   #48
65 GMC
I got my parts today. They look great I will post some pics when I get a chance to install it.
65 GMC is offline   Reply With Quote
Old 01-18-2019, 12:31 AM   #49
Captainfab
60-66 Nut
The Wilwood clutch masters went up in price again, so I had to raise my price on this conversion.
Old 02-11-2019, 03:58 PM   #50
roll_the_dice
roll_the_dice's Avatar
Everything looks awesome and shipping was super quick. Before I powder coat anything, I have a question.
I received my kit today. I am a few weeks away from installing, but was looking over the pictures and everyone's input. Pictured are what I received (along with the bracket and clutch MC). Forgive me if I missed something but is the piece in the lower right hand corner new for the 63-66 install? I have only seen it for the 67-72 trucks.
Thanks!
roll_the_dice is offline   Reply With Quote
