Old 04-22-2004, 06:27 PM   #1
cranknut67
cranknut67's Avatar
to cut or not to cut?
I have a set of thorley headers that I wanted to install in my '67 but there is a crossmember in the way - I have looked at other trucks in the same year range but they don't seem to have this same crossmember... it is between the main front crossmember and the transmission crossmember and sits in the way of the torque converter directly underneath it.
I took out the manual trans when i first got the truck for an automatic, and don't expect to re-install a manual any time in the forseeable future. would it hurt it to cut this crossmember out of the way?
cranknut67 is offline   Reply With Quote
Old 04-22-2004, 06:33 PM   #2
crazy longhorn
Fabricate till you "puke"
No problem, cut the old bell crossmember out.....the auto trucks didnt have them. You can also run a stick(3spd) on the auto crossmember.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-22-2004, 06:46 PM   #3
Mixup
I took it out of my 69 when I switched from stick to auto.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 04-22-2004, 07:01 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
DITTO, MINE CAME OUT WHEN THE 3 SPEED DID.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-23-2004, 01:22 PM   #5
cranknut67
cranknut67's Avatar
thanks!
thanks! I will get to choppin' this weekend.
