Old 01-01-2018, 01:18 AM   #1
bbrriiaann1973
Problem starting truck after sitting overnight.
My truck will not start if it sits over night. The engine just turns over and over acting like it's not getting fuel. If I take off the breather and a pour a little fuel down the carb it fires right up. Once fired up it runs great and has zero problems starting the rest of the day.
The carb is not flooding like it would if I had to hold the throttle down to start it.
I have a 1970 c10 with a 383/700R4, 600 edelbrock carb, mechanical fuel pump.
Any ideas of how to fix it?
bbrriiaann1973 is offline   Reply With Quote
Old 01-01-2018, 03:20 AM   #2
rockyrivermark
If my truck sits for a long period of time it takes longer to start. Gas bleeds back to the tank, usually a week though.
When it won't start go to carb and manually give it gas at carb.
Gas squirt out down carb? Should be able to see it.
Choke shutting properly at cold start ?
Start with the simple basics first then report back
rockyrivermark is offline   Reply With Quote
Old 01-01-2018, 12:30 PM   #3
raggedjim
raggedjim's Avatar
Re: Problem starting truck after sitting overnight.
The fuel pump should prevent the gas from flowing back, if it isn't then it could siphon the fuel bowl. I tested mine by removing it and blowing back through the outlet. Burped gas for 2 days but found out it needed to be replaced.
As long as I start it once a week it is fine now, but longer than that and I have to crank the bowl full.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 01-01-2018, 02:06 PM   #4
bbrriiaann1973
It acts like it's not pumping enough fuel at low engine speed, it's a hi performance fuel pump designed to pump max pressure at high rpms. Would going to a normal stock fuel pump fix the problem?
I have installed a helper fuel pump in line of the mechanical fuel pump and it seems to help a little.
Cranking engine 30 times vs say 20 times with the helper fuel pump.
Old 01-01-2018, 02:09 PM   #5
geezer#99
geezer#99's Avatar
Do you have a heat plate between the carb and the intake?
Do you have a working choke?
geezer#99 is online now   Reply With Quote
Old 01-01-2018, 02:20 PM   #6
bbrriiaann1973
No heat plate. Electric choke is not hooked up
Old 01-01-2018, 02:31 PM   #7
HO455
HO455's Avatar
Are you running a Quadrajet? If so the problem is likely one of the well plugs below the float bowl is leaking and draining the float bowl overnight. You can pull the carb when it is warm and check for drips. (Sometimes they won't leak cold) If it takes a lot of cranking of the starter before it starts in the morning I would suspect the fuel pump being weak as an additional issue.
Good luck.
RIP Bob Parks.
Old 01-01-2018, 02:37 PM   #8
bbrriiaann1973
No I have a edelbrock carb
Old 01-01-2018, 02:43 PM   #9
Rufas
Rufas's Avatar
There's your problem. With power off, hook up the electric to a switch source and then adjust the choke. The choke is there for a reason, especially during winter months.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 01-01-2018, 02:44 PM   #10
rockyrivermark
Electric choke is not hooked up.
Hard to cold start
Hmmm? What could it be?
Old 01-01-2018, 02:50 PM   #11
HO455
HO455's Avatar
OK. Have you pulled the air cleaner and looked down the carb and watched the fuel spray when you wing the throttle? Doing this first thing when cold and later when warm so you can compare is valuable info. You should see two good strong streams of fuel spraying from the primary side.
RIP Bob Parks.
Old 01-01-2018, 02:58 PM   #12
Rufas
Rufas's Avatar
Hard to cold start
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 01-01-2018, 03:20 PM   #13
WorkinLonghorn
WorkinLonghorn's Avatar
Well, in BBrriiaann1973's defense, he lives in Phoenix. 40's and 50's and a few 30's maybe, same as here in L.A. I disconnected my choke over 20 years ago and have never had one problem with it starting right up after a few pumps of the peddle.
He just needs to take the advice here and check to see if the accelerator pump is spraying fuel into the venturi when the throttle is manually operated and if not then he needs to figure out why the bowl is dry (leak or draining back?) and fix it. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-01-2018, 03:28 PM   #14
bbrriiaann1973
Had problem before and after I had carb rebuilt
Old 01-01-2018, 03:48 PM   #15
RichardJ
For an overnight problem, you need to check the fuel lines between the tank and the fuel pump. A small leak there will allow the pump to pull fuel from the tank and air through the leak. It will run fine with no indication of a leak. With the engine off, fuel seeping through a small leak can evaporate fast enough, it will never drip on the ground.
Wrap a rag around an air nozzle and with the air pressure set really low, blow air into the fuel tank and hold. Have someone visually inspect the fuel lines for a leak.
If no leaks are found, I'd suspect the fuel pump.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 01-01-2018, 05:19 PM   #16
OBS454
The choke needs to be functional. Worked as a mechanic in south Texas for many years ... rebuilt a lot of carbs and set a lot of chokes for people having this same problem. Didn't take much of a drop in temperature for this problem to arise. The choke is part of the fast idle system also. Too low of an idle setting will cause problems also. Cold start choke butterfly should shut all the way when pedal is depressed (if vacuum choke pull off is in place to open the blade immediately - if not don't adjust it to where the blade closes completely) all the way on cold engine (not too strong on the spring - just enough to close). If you manually open the throttle while holding the choke closed you should notice the throttle resting position to now be slightly higher than before (fast idle cam adjusting screw holding it open) Depending on how good the accelerator pump is, a couple of pedal pushes all the way should throw enough fuel into the engine. Upon engine start the vacuum choke pull off should be adjusted to where the closed blade pulls open to the approximate width of a #2 pencil at the rear of the choke butterfly AND the fast idle cam is set to increase engine speed to approximately 1500 RPM. Tapping the pedal will often kick the idle down to the next step on the cam once the engine begins to run. During this time the choke should be receiving whatever voltage it is rated for and begin to move the metal coil. So, the engine is beginning to warm and the choke cap is beginning to warm. As the warming progresses you can tap the pedal again and the choke linkage should move down to the next step on the fast idle cam or completely off of it as the choke butterfly continues to open to it's final vertical position. You may have to bend linkage here or adjust the fast idle there and change the position of the choke cap. Don't just look at one piece of the system. All work together and you probably won't get it perfect the first time - let it get cold and fine tune it till it's right. When set correctly it's really nice.
OBS454 is offline   Reply With Quote
Old 01-01-2018, 06:23 PM   #17
B. W.
B. W.'s Avatar
Agree with what others have said. IMO, you do not have a fuel supply problem, you need a choke.
To confirm you have fuel in the carburetor:
Let the truck sit overnite.
Remove the air filter lid & look down the carb
Work the throttle with your hand going to wide open throttle
You should see fuel squirting out of the pump squirters (located between the front two holes, at the front of the carb)
If fuel is coming out of the squirters you have fuel in the carb. You do not have fuel issues.
Wire up your choke to key on power & check your adjustments. Instructions are on the Edelbrock website.
B. W. is offline   Reply With Quote
Old 01-01-2018, 10:47 PM   #18
Aberdare
Aberdare's Avatar
The "Squirters" you are referring to is the Accelerator Pump. Every Carburetor has Five (5) Fuel Circuits and each has their own specific job to perform to deliver fuel... These fuel circuits are; (1) Idle, (2) Low Speed, (3) High Speed, (4) Accelerator, and (5) Choke.
In regards to being hard to start after sitting overnight, if the Fuel Bowl is Vented (which alot of the older carburetors are)... a simple fix which is often overlooked, is the Bowl Vent being stuck open or in some cases, the vent components are missing altogether... allowing fuel to simply evaporate, thus emptying the Fuel Bowl or not having enough fuel in the bowl to allow for a proper cold start.
A properly set-up, adjusted and tuned carburetor will have all five (5) circuits functioning properly, thus to allow for proper cold starts, as well as warm starts & HOT restarts of the engine under all environmental conditions.
Consult the manufacturer specifications for your model, to properly "Bench-Set" your carburetor, prior to any final adjustments with the engine running.
Just my $0.02 worth.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 01-02-2018, 12:21 AM   #19
B. W.
B. W.'s Avatar
To be specific, the "squirters" are called "accelerator pump nozzles". They are part of the accelerator pump circuit. It's just easier to say (type) squirters. The accelerator pump itself is located on the left front corner of the carb. the attached picture shows one that someone "re-built" & installed the pump diaphragm upside down. If you look closely you can see the rebuilder (I use that term loosely) also bent the tip of the metering rod. Believe it or not, this engine ran pretty good, just a little rich due to the needle.
As far as the gasoline in the fuel bowls evaporating overnite - not gonna happen. All carburetors are vented, the vent system is controlled on newer carbs to reduce evaporative emissions. (Edelbrock Performer series carbs are open vent) But, regardless of the type of venting, you will not lose enough fuel overnite to make a difference. If you see fuel coming out of the accelertor pump nozzles you have fuel in the bowls.
Old 01-02-2018, 12:29 AM   #20
bbrriiaann1973
Thanks for the info, so not having the choke hooked up will not put enough fuel at start up?
Because once it starts up it runs great for the rest of the day. Starting and stopping
Old 01-02-2018, 04:21 AM   #21
Rufas
Rufas's Avatar
That's correct. Hooking up you choke and adjusting it should solve your problem.
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 01-02-2018, 08:07 AM   #22
bbrriiaann1973
Ok I will try this! I never hooked it up because here in Phoenix you don't need a warm up period.
Old 01-02-2018, 10:16 AM   #23
geezer#99
geezer#99's Avatar
It might solve your problem!
Could be you’re boiling the Fuel out of the bowl and need a heat plate.
FWIW the choke doesn’t add more fuel, it restricts the amount of air.
Old 01-02-2018, 10:26 AM   #24
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
CaptRMW is offline   Reply With Quote
Old 01-02-2018, 04:51 PM   #25
Blakeman350
Blakeman350's Avatar
Hard to cold start
If sarcasm if the best solution you can contribute maybe you shouldn’t contribute at all. Just my opinion.
I had a similar problem on my 67 and I figured out it was a loose hose clamp on the rubber line between the pump and the line filter before the carb. Turns out it was just enough of a leak to drain the line and the float without leaving much indication.
Blakeman350 is offline   Reply With Quote
