Old 01-04-2018, 03:46 PM   #1
Desert1957
Desert1957's Avatar
Anyone see this NEW LS front accessory drive kit?
http://www.hotrod.com/articles/holle...ium&utm_source
Desert
Desert1957 is offline   Reply With Quote
Old 01-04-2018, 03:51 PM   #2
Desert1957
Desert1957's Avatar
Re: Anyone see this NEW LS front accessory drive kit?
Forgot the pic
Desert
Old 01-04-2018, 04:02 PM   #3
joedoh
joedoh's Avatar
so much room for activities!
Old 01-04-2018, 05:46 PM   #4
youngrodder
youngrodder's Avatar
I like how clean it looks. The price looks to be around $2,500. I think my friend gets a discount on Holley stuff. I might need to look into this more.
Thanks for the info.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-04-2018, 06:30 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks nice, but man...... $2500? Have any of you checked out Murphy's stuff? I'm going to use his brackets on my 5.3 in my 71 Camaro.
http://www.lssimple.net/
Ryan
1969 Chevy milk truck
Old 01-04-2018, 10:38 PM   #6
Advanced Design
Advanced Design's Avatar
The system looks really good...and compact. Priced at $1,800 from Holley and in December was on sale for around $1,600 as I recall.
https://www.holley.com/products/acce...s/parts/20-185
Advanced Design is offline   Reply With Quote
Old 01-05-2018, 04:16 PM   #7
youngrodder
Looks like I had old pricing. My buddy did say he orders from Holley directly and receives a discount. It helps that his shop restored a Mustang for the owner of Holley. He also prototype'd some products on his 2nd gen Camaro that went to Sema back in 16'.
Marc
Old 01-05-2018, 08:56 PM   #8
Advanced Design
Marc
That is a good connection Marc.
Probably price dropped due to competition. Which is great....anyone notice the Holley fuel injection priced to compete with FiTech?
Old 01-05-2018, 10:12 PM   #9
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
That's a very nice set up!
ChuckDriver is offline   Reply With Quote
Old 01-06-2018, 03:14 AM   #10
iowaboynca
iowaboynca's Avatar
my only concern would be the custom waterpump
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 01-06-2018, 03:35 PM   #11
Desert1957
Desert1957's Avatar
Great point, Might be good idea to by an extra water pump for down the road. Just in case availability is an issue down the road.
Desert
Old 01-06-2018, 03:56 PM   #12
joedoh
joedoh's Avatar
doesnt the article say it uses an C7 vette pump?
Old 01-07-2018, 05:59 PM   #13
youngrodder
Yes, that's how I understood it as well. I figured it was an off the shelf item if you needed to replace it.
Marc
Old 01-07-2018, 06:06 PM   #14
Advanced Design
It uses design elements of the C7 water pump. So, if a water pump goes bad, you will need one from Holley is how I interpret the information they provided.
Home / Accessories / Drive Brackets / Complete Kits / Holley Mid-Mount Complete Accessory System
20-185 - Holley Mid-Mount Complete Accessory System Image
Larger Image
HOLLEY MID-MOUNT COMPLETE ACCESSORY SYSTEM
LS Engine Drive includes SD7 A/C Compressor, Alternator, P/S Pump, Tensioner, Belt, & Pulleys
PART# 20-185
$1,999.95 Suggested Retail
$1,799.95 Your Price
Estimated shipping date: 01/22/2018
Free Shipping
Qty: Add To Cart
Starting at $159 a month with Learn More
Fits ALL LS engines except with dry sump and/or supercharger. Original belt alignment is not a variable as the water pump and crank pulley are included.
OVERVIEWSPECSTECH RESOURCES
Holley’s Mid-Mount complete accessory system has all accessories pulled in tighter than other accessory drives. At the heart of the system is a “bracketless” design (Patent Pending), where the accessories bolt directly to the water pump for a clean, integrated form. The design offers superb engine visibility to show off your horsepower, not your accessories. Among the many swap friendly features are bottom heater outlets for clearance in tight applications. The Holley designed alternator is just as innovative. This premium alternator utilizes hairpin/square wire, 6-phase technology as found on the C7 Corvette. The water pump also shares its design efficiencies with that of the C7 Corvette. The compact and reliable SD7 A/C compressor and Type II P/S pump with baffled reservoir are also integrated. The Mid-Mount drive completes Holley’s trilogy of accessory solutions giving a third option compared to the High and Low-Mount previously released. All three accessory solutions are for LS engines. When we say “complete”, we mean complete. The Mid-Mount system comes with everything you need. All accessories are included; the water pump, A/C compressor, Alternator, P/S pump with reservoir, and the crank damper. All pulleys and the belt are supplied. Even heater hose adapters, power steering to -6 AN hardline, and the alternator plug/harness are included. Easy assembly was a priority during the entire development of this accessory solution. Color graphical instructions walk you through every step of the ultra-easy installation.
Features:
Bracketless accessory mounting with ultra-easy assembly
Bottom outlet heater hose options for swap application clearance
LT1 style hairpin premium 150 amp alternator
LT1 style water pump cartidge design
Compact SD7 A/C compressor
Type II power steering pump with baffled reservoir
P/S adapter hardline to AN -6 adapter included
Steam tube input port
Shortened top outlet nipple for more radiator hose turns and routing room
OE pulley ratios for optimal accessory performance
No adapters/spacers required!
Works with all common aftermarket and factory throttle bodies and intakes.
Works with VVT applications
Works with Hooker turbo manifolds.
Old 01-07-2018, 06:09 PM   #15
Advanced Design
Pretty compact footprint.
The belt wrap on the crank and ps pump looks minimal, though I am sure Holley engineered it to work well.
Other thoughts?
