Re: Gen V Engine swap info
I used a type II pump, removed the vac pump. Machined up an aluminum bracket that mounts to the 4 holes that the vac pump used.
Im going to delete the DOD/AFM so hopefully the engine will make enough vacuum to operate the power brakes. If not i will just add an electric vacuum pump. I didnt like any of the aftermarket offerings to mount a power steering pump, and felt this might be a better solution. |
| Bookmarks |
