Old 01-05-2018, 11:29 PM   #26
gigamanx
Re: Great Grandads '53 3100
Originally Posted by Tesone View Post
First update in several months. That being said I've still been working on the truck quite a bit. I've been keeping my instagram page current so feel free to request to follow me if you'd like to follow along. My username is stesone11
This is fairly abbreviated so forgive me. After I got the engine running, I got the the ECM and Throttle control box mounted under the dash. Managed to get it done reusing some parts from the fuel tank straps.
And discovered I would indeed need to add some tubs.
Built the tubs from a trailer fender. It was a single fender I split in half and narrowed a bit and filled in with sheet metal.
Looks like you and I are running the same wheels. I had the same tiny bit of tire on the bed side. I used 3" spacers to get the tire out as far as possible, but I still need tubs. They look like the fenders I've seen at Tractor Supply. Thinking of getting one of those myself and cutting them down to size.
Curious to know about your front wheel and tire size? I have 18" Riddlers with 4.5" backspacing for the front. I haven't checked to see what tire size I need, but yours look pretty darn close.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
