Old 01-04-2018, 06:36 PM   #1
chris989
tbi surge
Hello all,
My tbi build has been better than expected but recently i have developed an issue where when decelerating my engine will surge. It feels almost like i am driving gas,brake,gas,brake.
I checked all the basics and did a little data logging and can not find anything. I thought it might be the 4l80 locking and unlocking but the MSD controller does not show any signs of it.
Has anyone ever come across this? I posted over at 3rd gen and gearheads but i did not get any responses.
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 01-07-2018, 01:16 AM   #2
andyh1956
Re: tbi surge
Sounds like your Idle Air Control Valve Pintle is not seating properly at closed throttle. Or MAYBE you EGR is fluttering due to malfunctioning vacuum controls. Plug it off & drive the truck to eliminate that part. Also disconnect the cruze cable & drive it.
andyh1956 is offline   Reply With Quote
Old 01-07-2018, 12:59 PM   #3
chris989
Re: tbi surge
I just did some data logging yesterday and conclude there is nothing in the TBI system that is causing it.
It has to be the stall converter locking and unlocking, I though it my be something with shift solenoids but i downshifted as i slowed from 60 - 0mph and it does it in every gear.
Old 01-07-2018, 01:57 PM   #4
Morgsie
Re: tbi surge
What ECU are you running? My TBI caprice use to surge and on deceleration aswell. Try and disable "Async" injection that's what solved my surging issue.
Morgsie is offline   Reply With Quote
Old 01-08-2018, 09:27 PM   #5
chris989
Re: tbi surge
i think i have the 7747, the data is on the computer in the shop.
I do not have any surge at idle or while cruising, It is smooth as can be. I will look into the async injection.
Talked to my transmission shop today and they feel it could be the controller and I am skeptical of it too. A few months ago it was giving me TPS errors and would not calibrate. MSD had me calibrate the system with the motor running. It would not calibrate with just the ignition on. I think i will have summit ship me a new one and test it.
Old 11-18-2025, 08:58 PM   #6
chris989
Re: tbi surge
Sorry guys,, i thought i closed this out..
It was a leaky injector, New but still junk. A tbi cuts fueling on decel, the injector was randomly dumping gas causing the surge
