Old 01-07-2018, 06:32 PM   #1
indianpride77
indianpride77's Avatar
76 short bed
Ok so I am trying to find out some correct info. I am going to swap from a stepside to a fleetside. I was told that I need to find a bed from a 73-78 bed. But I was reading that the main difference between a 78-79 is the 79 has a gas door? So is the mounting of the bed the same cause I can deal with a fuel door. If that’s the difference
indianpride77 is offline   Reply With Quote
Old 01-07-2018, 09:43 PM   #2
73kay
Re: 76 short bed
Yes I'm pretty sure any 73-87 bed should work for you. Fuel door is the only change I think. Also just be sure to find a bed that has the gas cap/door for the correct side for your truck.
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
