Old 01-08-2018, 04:22 PM   #1
outfield
Re: post your 67-72 4x4
The Rancho Shock Part Numbers on your Invoice 9001 / 9112 are the 4 inch lift shocks for 1973 to 1987 Trucks, the front shocks are the same back to 1969 I believe, I believe the rear were different though, but the 9112's are so long, they probably fit anyway.
The invoice says SUP HD springs 01-255, these are Super Lift 6 Inch Lift front Springs for 1967 to 1972 Chevys. So the front shock may be a tad short...
I see an add a leaf for the rear. We would sell a 4 inch block kit, and add a leaf kit when lifting Chevys 6 inches, I don't see a 4 inch block kit though.
There is a Rancho steering stabilizer and bracket listed also.
Hope this helps.
Originally Posted by Killer Bee View Post
thanks for the boost everyone
still waiting for reply to my email inquiry to Tuff Country regarding old p/n translation on the lift specs..
but either way, there was $1800 of '99 money put under there.. shocks are about all needs replacement I suspect..
maybe one of y'all know more about this? anyone know old numbers? I crapped out on google..
and yes it was known to all previous owners and titled as a '71 although we know different
outfield is offline   Reply With Quote
Old 01-08-2018, 05:18 PM   #2
Killer Bee
Killer Bee's Avatar
Hope this helps.
thank you very much for your thoughtful and informative reply!
I guess I'd have to call tuff country, sent a courteous email and two follow ups a week apart.. seemed reasonable..
I'll take some pictures underneath and bounce that off your info to see where it's at..
previous owners may have made changes since that invoiced work but I don't recall seeing any blocks under there..
not my area of expertise by any means so all info much appreciated, thanks again!
Killer Bee is online now   Reply With Quote
Old 01-08-2018, 10:07 PM   #3
outfield
By the look of the stance of your Burb I would say is has a 6 inch lift. The front must be all springs, which I see it is. The rear can be all springs, or blocks and springs as needed. Definitely take a picture or two of the rear set up and we can see what you have. An add a leaf is uaually a sorter thick leaf found near the bottom of the spring pack. All the stock leaves will be the same thickness, except the bottom overload spring.
Old 01-09-2018, 12:28 AM   #4
mud.man.rj
mud.man.rj's Avatar
All the add a leaf kits I buy are a full length minus about 1" each end than the top leaf, the super thick short leaf is an overload, but some companys "try" to seel them as an add a leaf but don't actually lift the truck any more than the thickness of the leaf cause the ends of it doesn't touch the spring above it.
Someone may have had a 4" block they used with the add a leaf in the rear. I keep a bunch of different heights in my shop. Guess you have to look.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-13-2018, 04:52 PM   #5
beadblaster
beadblaster's Avatar
1971 k10.I am the 2nd owner and have had the truck for the last 35 years. I just finished frame off. Truck has 64” atlas progressive leafs in rear and 54” up front. Cross over steering,King remote resevoir shocks,37” maxis razors on raceline monster rims. I made front bumper,cut down stock rear step bumper,warn 8274,rock sliders plus a ton of other stuff.
beadblaster is offline   Reply With Quote
Old 01-16-2018, 01:00 AM   #6
Voodoo556
Voodoo556's Avatar
Thats a baaaadazz rig right there! Luv it!
Good work!!
Voodoo556 is offline   Reply With Quote
Old 01-16-2018, 06:09 PM   #7
Turnip Truck
Turnip Truck's Avatar
How are the road manners with the 54" fronts? Are you running a sway bar? Awesome truck BTW!
Turnip Truck is offline   Reply With Quote
Old 01-16-2018, 06:17 PM   #8
beadblaster
Not sure how it is with the 54s as I just finished truck. I have king shocks on it with compression adjusters and a Currie anti rock sway bar on the rear of the truck. I may add a anti rock on the front if it is really soft but the compression adjusters on the king shocks should help. To add the Currie sway bar to the front is super tight because the cross over steering uses a 2 wd steering box which puts the pitman arm opposite of the 4wd box. I will have to cut the sway bar arms and add bends to clear.
