#976 |
Re: How about some pics of bagged 47-59
Good looking green G M C !
#977 |
Was able to get a better pic of the 57, aired up and down
2017 king ranch power stroke 57 chevy big rear window, camaro front clip, rear is notched 57 chevy truck, air ride, ls swapped. 52 chevy truck waiting its turn. |
#978 |
Love the GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#979 |
Nasty looking.
![]() Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#980 |
![]() Join Date: Sep 2016
That's sick man! Odd question...did you go with hard lines or soft lines? What size?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#981 |
Gigamanx, I think I have the same question.
Getting ready to plumb my airbag system and would like to hear experiences with either hard or soft line too. DOT approved push-in fittings are kinda expensive and I hear a lot of guys complain about chasing down leaks. My plan is to plumb the airbags in -4 AN fittings (1/4" tube) with aluminum line. Stainless might be a better option, but it is difficult to flare without cracking and the fatigue resistance of the aluminum should be ok if it is fastened to the chassis correctly. To keep the cost of down for the AN fittings, I'm using steel JIC fittings, nuts and sleeves. I have a Parker Rolo-flair tool to make the flares in the aluminum and have had good luck making leak free connections with it. For the threaded connections, the plan is to use a anaerobic thread seal (Locktite 565) instead of teflon tape or pipe dope. Any other suggestions from guys with bagged trucks? |
#982 |
there isn't much difference in either setup, more aesthetics rather than function. I had no problems with soft line and PTC fittings. I used blue monster tape on threads. I used 1/2 lines on my last bagged truck with accuair manifold. Current one Im using 3/8 with manual valves. I'm sure you may read plenty of debate out there, but I'm just giving my take with it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#983 |
What's your ride height aired up?
Representing for the 504. ![]() |
#984 |
I recently bought this truck, will measure ride high tomorrow,
2017 king ranch power stroke 57 chevy big rear window, camaro front clip, rear is notched 57 chevy truck, air ride, ls swapped. 52 chevy truck waiting its turn. Last edited by Slowy-gonzalez; 01-07-2018 at 10:03 PM. |
#985 |
I am using 3/8" lines Accuair valve. I ran rubber air line up front and have PTC nylon line out back. So far 10,000 mi all good. My truck is 5000lb.
#986 |
#987 |
Sorry I didn't mention that is was a Jag IRS - and there's no C notch. It was narrowed about 3" side to side and tube steel half shafts replace the Jag's forged half shafts.
The ladder truss supports the differential and is mounted on urethane bushings. The bolt that hang the diff in the truss are about even with the bottom of the wood boards in a stock bed. This bracket assembly holds the differential assembly in position and keeps the pinion angle constant The airbags ride on a trailing arm that connects to the Jag's LCA. It is a 5" Slam bag that does the same job as the Jag's coil-over springs. Another photo The front of the airbag trailing arm - it has the same roll center as the LCA of the Jag IRS And yes. a four link and a c-notch would have been a lot easier. But it's all about the nostalgia of the Jag rear end |
#988 |
Oh, and here's a photo of the truck with the running boards on sitting on the bump stops. There's about three inches from the running boards to the concrete floor.
#989 |
The jag rear is well worth it, top notch job.
Mudman.
#990 |
When I was a kid in the 60's, a lot of the plastic model kits of hot rods had Jag rear ends - I'm sure there's better solutions out there, but it is all about the nostalgia and childhood memories.
Thanks for the compliment, Mudman! |
#991 |
Well you know many won't see it or even know what it is but...you do and I think of that on my own builds, it's about what we want and like right, but cool when others appreciate what we've built too. Keep at it, very nice build.
Mudman.
#992 |
Thank you for the pictures and explaination. Very nice work.
#993 |
#994 |
Very nice GMC man,
Make sure you get a couple of linear actuators so you can flip a switch and make your wood bed open, Be a shame for others not to see your work. Very very nice. To me, its always whats on the inside...
"All the best, Phil" My 53 IFS air bagged Upgrade Here One of my threads for this build... http://67-72chevytrucks.com/vboard/s...12#post7662512 |
#995 |
Thanks for the nice words!
At this point, I just want to drive it! No more 'enhancements'/science projects. |
#996 |
[attach]
#997 | |
Posted via Mobile Device |
#998 |
New wheels.
#999 | ||
#1000 |
