Old 01-09-2018, 11:30 AM   #1
ron lechman
Question Factory under dash a/c ?
I found an under dash air self contained air conditioning unit installed in a 1972 Jimmy located in a wrecking yard. The fans works and I bought it for $50.00. I would like to install it into my 69 C10. It looks very well made and has a nice metal Jimmy name plate on it.
I'm wondering if this is a GM product that was offered by GM parts department to retrofit non-ac vehicles or an aftermarket unit.
Does anyone have information on a unit like this?
I'd like to change the Jimmy nameplate ( 1" X 6 1/2 " ) to an appropriate name plate for my 68 C10 and a couple of the outlet vents are damaged and need to be repaired or replaced.
Can anyone help with that?
I've attached a few pictures of the unit.
ron lechman is offline   Reply With Quote
Old 01-09-2018, 01:01 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Factory under dash a/c ?
Check with these guy's they know their stuff.
They do refurbs on old equement to!
1
https://www.classicautoair.com/?q=GM_OEM_Parts.html
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-09-2018, 01:24 PM   #3
ron lechman
I just sent an email to https://www.classicautoair.com/?q=GM_OEM_Parts.html Hopefully they can recognize my ac unit.
I didn't see anything on their website like my unit.
Old 01-09-2018, 03:51 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Potentially dealer installed, or some A/C outfit local to them did it and then the dealer put that label on. That's not a "factory" A/C evaporator set up.
~Steven
Simi Valley, CA
Old 01-09-2018, 04:15 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Aftermarket unit, someone just stuck the Jimmy badge on there. Looks good though, someone wanted you to think it was factory
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-09-2018, 04:54 PM   #6
Andy4639
Old member
Andy4639's Avatar
Here is another company that knows about under dash units.
http://www.oldairproducts.com/catalo...eaca4cdd0b53b3
