Old 01-06-2018, 10:38 PM   #2251
Xeen
Xeen's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Originally Posted by sduckworth13 View Post
Brian, you know Vic well enough half aceing isn't part of his repertoire . Nice work Vic!
LOL! He knows I gotta poke him in the ribs from time to time.
Vic is a good engineer and a good engineer builds robustness into his designs, trust me he knows it was overkill because it's obvious two bolts would have done the job just fine, which is why my remark is funny and I'm sure at the very least I got a half smile out of it.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-07-2018, 06:12 PM   #2252
Vic1947
Vic1947's Avatar
Yep, Brian, sometimes cosmetics overrides practicality.
Speaking of cosmetics, I've been tinkering with the radiator cover the last couple of days. The fan controller sits on top of the shroud and is adjustable, so my first thought was to build a cover with a window in it that would allow me to easily access the box. To do that, I built a stair-stepped panel which fit around the controller okay, but looked way too busy. So onto the junk pile it went. Plan B looks nicer but will require that I remove the panel for any adjustments. That shouldn't be an issue once the limits are set... if they even need to move from the vendor settings.
And the reason I used five fasteners was due to a screw up. Failed to notice there was a large hole in the core support right where I drilled one of the fastener holes. So (full disclosure) there are four tapped holes and one dummy. Well, two if you count me.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 01-08-2018, 02:18 AM   #2253
nuke1
nuke1's Avatar
Truck is turning out amazing!!! hope to get mine that nice once again!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-08-2018, 02:14 PM   #2254
Low Elco
Whatever you do, Don't let Vern see that cover. You'll be busier than you wanna be!
Low Elco is offline   Reply With Quote
Old 01-08-2018, 06:02 PM   #2255
Vic1947
Vic1947's Avatar
You know I'll drop whatever I'm doing if Vern wants a cover for the Jimmy. You been massaging it any this winter?
Victor
Old 01-09-2018, 09:18 AM   #2256
Low Elco
Nope, it hasn’t moved since October. I’ve been.... busy.
Hope this works.
Old 01-10-2018, 12:23 PM   #2257
knomadd
knomadd's Avatar
CRLS is looking good Vic! Keep it up, you'll get it done in no time (or it will seem like it to you, once you've finished it). That's how it feels for me now... the wife reminds me that is not the case... She told me this past weekend it's been "2 years since you last drove it." I had to remind her it was only 17 months.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-10-2018, 01:38 PM   #2258
Vic1947
Vic1947's Avatar
Thanks, Duane! We plan to attend the LMC Truck show in Fort Worth the first of May, so I have a solid deadline now. We passed the five year mark this month, but who's counting, right?
The wiring job is slowly winding down. I modified the console slightly and test fit it over all the bundles of snakes this morning and it looks like it will clear everything. I still have a few questions on the GMPP harness that came with the powertrain. The info is out there, I'm sure, but it's tough to find. Most build threads are geared toward modifying OEM harnesses but my GMPP unit has a few undocumented features.
There are three pigtails shown in the attached photo.
One has four wires labeled A-BRK LIGHT, B-CAL A/B, C-CANCEL O/D and D-DYNO. I don't think I need any of these for my setup.
Another has a VEH SPD label on it and has a purple/white wire and a green/black wire. According to the internet, the purple is VSS high and the green is VSS low. Pretty sure they feed into the Classic Instruments SN74Z interface box and provide the pulses for the speedometer.
The third pigtail has three loose wires for engine oil pressure, speed out and RPM. I figure the oil pressure feed won't play nice with the Classic Instruments gauge, so I installed their sender instead and will truncate the GMPP wire. The speed out wire is needed for the Hot Rod Therapy cruise control. I'm hoping the RPM signal will drive the tach. I think it sends pulses consistent with a 4 cylinder and as long as you set the tach for that, it will work. At least I hope so. The SN74Z interface box can do either speed or tach but not both. Don't even want to think about buying another one.
Victor
Old 01-17-2018, 08:22 PM   #2259
Vic1947
Vic1947's Avatar
My "Painful" wiring project is just about done. Mostly just the amps and speakers left to do. Hard to believe how much is needed for all the gizmos. The radio has a microphone for the Bluetooth and VR, and I failed to route the wire inside the A-pillar like I did for the camera and map lights. So it gets routed up next to the door seal where it will clip on the visor. Won't be able to tell hardly at all when it's done. I'll hook up the push button start after the truck is running and sorted out.
Need to get the glass guys out to install the windshield and back glass. I could do it myself if I didn't mind them leaking.
Victor
Old 01-17-2018, 08:32 PM   #2260
rustytruck50
rustytruck50's Avatar
Really like the treatment on the gauges & glove box door!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 01-17-2018, 09:05 PM   #2261
jeh
jeh's Avatar
That dash with the black looks great!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 01-18-2018, 08:59 AM   #2262
Low Elco
Slowly, but Surely....
Old 01-19-2018, 01:40 PM   #2263
knomadd
knomadd's Avatar
Looks great Vic! Keep it up, you're almost there.
-Duane
Old 01-26-2018, 07:14 PM   #2264
Vic1947
Vic1947's Avatar
Thanks, everyone. I've been going back over fittings and re-tightening them all. The power steering reservoir is full and I used the vacuum fill tool to check for leaks in the cooling system (none) and then load the system with DexCool antifreeze. Worked like a charm... probably the first time I've ever performed that task without making a mess.
The outside mirrors arrived recently. They're APR GT3 carbon fiber pieces. I weighed one on the digital scale and it came in at 5.6 oz. I hope I can mount them in the small triangles that came with the one piece windows.
I need to bleed the brakes and put in some 93 octane and I think I'll be ready to fire off this puppy in a few days. I haven't been able to get in touch with the guys that installed my last two windshields... think they may be out of business. I'm probably going to just do it myself. I've done a few (many years ago). Mostly Chevy cars, but the principle is the same. I'm thinking about upgrading to the windshield gasket with the stainless reveal molding. Was wondering if anyone has any experience with that (good or bad)?
Victor
Old 01-26-2018, 11:48 PM   #2265
rustytruck50
You've got to be getting pretty excited! Looks great!
-Doug
'05 RCSB Sierra 2WD
Old 01-27-2018, 11:33 PM   #2266
Vic1947
Vic1947's Avatar
Yep, won't be long now, hopefully. Still have a few things to do, though. Today was devoted mainly to the brakes. Scott came over this afternoon to assist, but it seems like all we did was chase leaks. Unlike the cooling system, I think 9 out of 10 connections leaked. I'm not sure why all the issues. Everything in the system is new. Hard lines, rubber lines, fittings, brakes, m/c... you name it. Not one used part in the whole dealio. Some of the connections had to be tightened 4-5 times to get them to stop weeping. Way back, I thought about converting all the double flare connections to AN. Now I wish I had. I reckon when the hydraulic boost pressure hits the system, I'll be back chasing leaks and cussing again.
And to add insult to injury, I still have no brake pedal. Bled the m/c till all the air bubbles were gone, then reverse bled the lines till no bubbles. Pedal goes all the way to the floor and won't pump up. So there still has to be a significant amount of air in it somewhere. The tool I'm using can force fluid thru the orifices in the m/c, so I may try that tomorrow... or gravity bleed, although I've never had much luck with that. One way or the other, I'll get 'er done.
Victor
Old 01-28-2018, 01:25 PM   #2267
Jason7121
Jason7121's Avatar
Hi Vic thought I would chime in on the window moldings. After several attempts with mine and 4 different glass shops I got mine done. The trick for us was to use precision brand weatherstrips and factory stainless trim that we polished. Aftermarket trim fits terrible. There were 2 different used on these trucks a deep groove and shallow groove trim the deep one works better to hold trim in the gasket. Whatever trim you get make sure gasket matches either deep or shallow. As far as brakes go I had same issue your having. I had luck bleeding the system with engine running and using the hydroboost to help push fluid through the system and also adjusting the hydroboost push rod until there was 1/2 Freeplay. Hope this helps your build looks great!
Jason7121 is offline   Reply With Quote
Old 01-28-2018, 01:30 PM   #2268
rustytruck50
That brake stuff is/can be unnecessarily frustrating. I fought that last summer with my '72. The m/c that the parts store swore up & down was correct turned out to be wrong. I couldn't get the brakes to bleed by gravity or with a hand vacuum pump. Once I looked it up myself on another parts store website & had them cross check the number, the problem was solved & reassured myself that I did remember how to do brakes! You may have been given the wrong master on yours to have it do the same thing....just a idea. I'm sure you'll get it figured out.
-Doug
'05 RCSB Sierra 2WD
Old 01-28-2018, 01:33 PM   #2269
rustytruck50
-Doug
'05 RCSB Sierra 2WD
Old 01-28-2018, 01:37 PM   #2270
Jason7121
Jason7121's Avatar
Yeah check push rod between hydroboost and master cylinder for adjustment if pushrod is to shallow pedal will have alot of Freeplay and go to the floor.
Old 01-28-2018, 02:11 PM   #2271
Aberdare
Aberdare's Avatar
Yep... probably the single most overlooked item when mating new parts together. After mating the master cylinder to booster, adjusting the pedal to booster rod free play should bring everything into proper working order.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 01-29-2018, 12:06 AM   #2272
Vic1947
Vic1947's Avatar
Thanks, Jason, your advice on the trim is what makes this forum so valuable. I've been on the fence about converting to the reveal trim as I think it looks very nice. However, like anyone else that's purchased aftermarket trim from the various vendors, I figured it might be tough to work with... not to mention the heartburn if it doesn't turn our well. I had to go great lengths to get the aftermarket stainless drip rail trim to fit, so I'm thinking maybe I'll give the windshield trim a pass. Besides, apparently they don't make the matching trim for the small rear window so it would be plain anyway.
How are things in Visalia? I bought my first '69 GTO RA4 Judge from Arnold Wiebe there when I was stationed in Lemoore. Had to bribe Kathy with ice cream to get her to "just go look at it".
Fortunately, I got the entire unit (hydraulics, m/c, linkage, etc.) from CPP so it's all correct. Turns out the problem was mainly air in the system. I have a Phoenix Systems "one man" bleeder setup. They make it look easy, but I can't seem to achieve the same results. It does fill the lines quickly, but there's always residual air. Today, Kathy and I used the old reliable method of one person pumping the brake pedal and the other cracking open the bleeder valves. Two trips around the truck and we had pretty good pedal. Will give it one more go after the engine is running and the hydraulic assist is functional. The really good news was that there were no new leaks. At least until the assist kicks in.
I may need to revisit the free play once it's running. I adjusted the threaded rod coming out of the back of the Hydra-Stop just to where there's no preload. I can rotate the rod maybe a half turn back and forth between the spots where it tightens up, so I split the difference and snugged up the jam nut.
Rest of the day was spent sorting out a few electrical gremlins. The only thing left is the E-Stopp parking brake. It worked great when I tested it during the installation. However, when I applied power to it the the other day, it partially set the brake and quit. Now it just beeps. So I'll be on the hook with them tomorrow to see if they have any suggestions.
Victor
Old 01-30-2018, 12:05 AM   #2273
Jason7121
Jason7121's Avatar
Everything is good here in Visalia that dealer you mentioned is no longer there. I worked at Visalia GMC for several years now in Selma at Chev dealer. I forgot you had small rear window so your right no molding��
Old 01-30-2018, 01:32 AM   #2274
ChuckLee
I had those APR GT3 mirrors on a RX7 last year. They look sweet....just hope you never need to use them in any functional way lol.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-30-2018, 05:44 PM   #2275
knomadd
knomadd's Avatar
It's been too long since I've been on the forum, I had some suggestions for you on the window trim and the brakes, but everyone else has already said them, and you've pretty much figured it out. That's why this forum is so great! So many members willing to help out when they can.
Oh, to add to the window trim info, I've found out the '70 and older stuff is the better windshield stainless. The tab is centered in the gasket, not just deeper. The '71 & '72 trim has an offset and shallower tab, and my glass guy swears they are a pain in the rear to get seated properly. And he told me if I bought aftermarket stuff he wouldn't touch it. I haven't had him install my trim yet though. I need a new windshield first. I'm just enjoying driving it too much to pull it apart again.
-Duane
