12-29-2017, 08:48 PM | #26 |
BlahBlahBlah
Re: 67 Camaro Build
Im not a big fan of Camaros but when you posted Grumps Camaro that brought back some fun memories. I think a 67/68 Camaro set up with the same stance and tire wheel combo would be really cool to bomb around in.
01-02-2018, 11:45 AM | #27 | ||
Re: 67 Camaro Build
Building a jig/body cart that won't fall apart and is next up.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
01-03-2018, 12:17 AM | #28 | |
A guy with a truck
Re: 67 Camaro Build
Keep up the good work!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-06-2018, 12:51 PM | #29 |
Re: 67 Camaro Build
Bummer, that looked like it could have been a good'n! I’ll ask around and keep my eyes open for yah Chris, thanks.
Here's a little more jig/cart progress and then a planets are aligning kind of moment! Our new beauty tank has been on fumes and the second it was out our 10lb wire spool ran out also.
01-08-2018, 11:18 AM | #30 |
Re: 67 Camaro Build
Some poly bushings, tub o’ grease and oil filter adaptor bolts showed up from Summit. Slid the subframe back under the car again with the new bushings prior to repairing the bad LR body mount hole. Toying with the idea of making our jig able to accept the subframe for front clip fitment later (?).
01-10-2018, 12:23 PM | #31 |
Re: 67 Camaro Build
Placed an order a few days ago for some 13ga sheet after we were unable to source it locally. Speedy Metals was certainly spendy, Ha, I mean speedy (compared to the cost of a new subframe this was way cheap)! https://www.speedymetals.com/pc-2681...eel-sheet.aspx
01-12-2018, 11:37 AM | #32 |
Re: 67 Camaro Build
Tank swapped and more wire in the machine, our little Lincoln is a happy camper. Here’s the first layer of subframe repair.
01-13-2018, 12:03 PM | #33 |
Re: 67 Camaro Build
Second layer.
01-13-2018, 12:34 PM | #34 |
A guy with a truck
Re: 67 Camaro Build
Nice work on that. Way better than buying new
01-13-2018, 06:34 PM | #35 |
Re: 67 Camaro Build
Well done! Always wanted to have a welding talent!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-15-2018, 10:56 AM | #36 |
Re: 67 Camaro Build
Thanks Chris I agree, much better than buying new.
Thanks Clyde, it's coming along pretty good. Flipped over for another pass, added some nice ugly weld on the end like the factory welds. Ha, thinking that'll do!
01-15-2018, 10:21 PM | #37 |
6>8 Plugless........
Re: 67 Camaro Build
Nice work. Much better than the rust hole before.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-17-2018, 10:22 AM | #38 |
Re: 67 Camaro Build
Thanks Ryan!
Hole’s been punched and subframe test fitted into the car, giving this particular repair a done stamp.
01-17-2018, 12:02 PM | #39 |
Re: 67 Camaro Build
Nice repair Brett. You weren't kidding about leaving the ugly welds on the end
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
01-17-2018, 09:53 PM | #40 |
A guy with a truck
Re: 67 Camaro Build
Looks factory, nice!
01-19-2018, 11:08 AM | #41 | |
Re: 67 Camaro Build
Thanks Chris, since we're only fixing one mount Mr. Picky Pants (me?) wanted to hide the repair. Back to the jig, mentioned this earlier making both the front and middle supports height adjustable in case we want to add the subframe with its mounts at some point and still level out the body shell. All thread pieces are slotted and cut as long as the tubes so they can be recessed flush but not fall in.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 01-19-2018 at 11:13 AM. |
01-19-2018, 03:40 PM | #42 |
Re: 67 Camaro Build
That's a very nice body dolly! Can you make one for my Camaro and my 40 Ford so I don't have to?
01-21-2018, 11:10 AM | #43 |
Re: 67 Camaro Build
Yepper, I’m thinking it’s gonna be nice! Hey Ryan, that is a good idea, but no..
Here’s how we’re anchoring the rear, using the old 2-piece frame bushings with the shoulders cut off for a closer flush mount. Then to the risers using the original shackles, it’s pretty dang snug and a bear to install but will hold the car very solid. Getting ready for a gusset party next!
01-23-2018, 10:26 AM | #44 |
Re: 67 Camaro Build
1, 2 & 6, gusset parties over, good times… I’m thinking this is gonna work with the subframe!
01-24-2018, 10:30 AM | #45 |
Re: 67 Camaro Build
Argh! Too much heat, pulled the uprights inward towards the gussets dangnabit! The alignment holes up front don’t line up any more, it just barely fit through the subframe and the center support section was off by a knat’s a** of popping into its alignment holes. Cutting the tops off and am resetting them.
It's another Mr. Bean moment...
01-24-2018, 11:17 AM | #46 |
Re: 67 Camaro Build
Sucks when that happens! Can you tack a bar across the top to hold your spacing while you reweld the gussets?
01-24-2018, 08:45 PM | #47 |
Re: 67 Camaro Build
That's just how it goes isn't it? Oh well, you'll get it fixed up.
01-24-2018, 10:52 PM | #48 |
Re: 67 Camaro Build
Big project... what’s been done looks pretty good. I'm so jealous
Bryan 1980 Chevrolet C20 LWB 2wd 2014 Harley Davidson Heritage Softtail 192.168.0.1 bullet force unblocked |
01-26-2018, 01:21 PM | #49 | |||
Re: 67 Camaro Build
So, after cutting the four tops off, cleaning off all the not so old weld and trueing everything up again. With the weight of the car tacked them in place with lots of tacks then pulled and final welded them onto the uprights again. Once satisfied with the support to body fit again went ahead and welded up the rest of it. Yippy skippy, shell went right on without any drama this time!
01-26-2018, 06:31 PM | #50 |
Re: 67 Camaro Build
Nice! Is the body ready for paint yet?
