![]() Join Date: May 2011
Re: Yet another 72 going under the torch, factory 3 speed on the tree!
Pulled the latches 1 is ok the other needs the spring replaced which I can do. I grind the crimped end off replace the spring and then I weld the pin in. Works good as new and the weld can be ground off if it would need worked on again. Let me know if still interested and I can get it repaired this weekend.
