Old 12-28-2017, 10:22 PM   #1
mongocanfly
mongocanfly's Avatar
Mongos 81 c30
this will be a very short build thread...I built this truck before I found this website and I didn't take many pics along the way..so ill just describe what I did and you can use your imagination for the rest..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-28-2017, 10:31 PM   #2
mongocanfly
Re: Mongos 81 c30
I had a need for a bigger truck to pull my Mahindra 50hp tractor so I went looking for a squarebody ton c&c truck..lucked up on this truck...it came from a local fire dept and only had 20200 miles on it when I bought it..it was kept inside most its life so there was no rust to deal with...it did have a bunch of holes in the doors from several different mirrors that had been put on it over the years...13 holes total in each door..the truck had a 350 with a sm465 trans and 4.10 gears...the truck ran great but lacked in power...
first order of business was to pull the 13ft utility bed off and shorten the frame..I cut a total of 5ft out of the frame..I bought all the metal and built my own cm style bed for the truck..sanded down the cab, fixed the body work and put a driveway paint job on it..the bodyshop i talked to wanted 7k to paint just the cab...i nearly had a heartattack..a lot of packages from lmc helped me redo the interior
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-28-2017, 10:39 PM   #3
mongocanfly
Re: Mongos 81 c30
I had been curious about the LS swap for awhile but couldn't find anybody that would talk to me about what all was needed to do one..I finally found chris at lightning rod speed shop..he was a big help and hooked me up with a lq9 and walked me thru what I needed ....btw he does LS swaps and does an outstanding job from what I saw while I was at his shop...
I was on the fence on wether to keep the sm465 or not but I figured if I was going full bore why not step up to a nv4500.. so now I've got the engine and trans figured out so another order to advace adapters got them coupled together...the swap went very smooth..I was impressed with how simple it was..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-28-2017, 10:46 PM   #4
mongocanfly
Re: Mongos 81 c30
some pics of the truck as it currently is..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-28-2017, 10:52 PM   #5
mongocanfly
Re: Mongos 81 c30
and some engine pics after the swap..couldn't be more pleased with the power I've got..and od..and my mpgs went from 10 to mid 16s..winwin ...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-29-2017, 09:28 AM   #6
cochino12
It followed me home?
cochino12's Avatar
Re: Mongos 81 c30
I love it! Great job on the flat bed
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-29-2017, 07:32 PM   #7
mongocanfly
Re: Mongos 81 c30
thanks Adam. .I ought to have my butt kicked for not taking pictures while I was building it...it came a long way from what I started with..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-30-2017, 05:11 AM   #8
Advanced Design
Advanced Design's Avatar
Re: Mongos 81 c30
That came out very nice! What engine mounts did you use?
A good friend that is an LS swap guru, has been on me to 6.0 my 88 crew cab dually from the current 454. Seeing yours tempts me more!
Advanced Design is offline   Reply With Quote
Old 12-30-2017, 06:08 AM   #9
mongocanfly
Re: Mongos 81 c30
thanks Doug. ..I used ebay mounts that put the engine in the stock smallblock location...
still got to get the ac hooked up...it'll have to wait for a while though...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-08-2018, 04:34 PM   #10
RotaryRocketeer
RotaryRocketeer's Avatar
Re: Mongos 81 c30
Nice work Mongo! That thing is a cherry!
I'm gathering the last few bits to do the LQ4 swap on my '76. Planning to run the 3 speed for at least a little while until I find a good shop to build the trans I have waiting in the wings.
Are you still happy with the eBay mounts? They're one of the few things I haven't pulled the trigger on yet. Just so many options. Been eyeing the Holley units that allow use of the factory SBC clamshells, but I'm not sure yet. I know I want some that retain the factory position though.
RotaryRocketeer is offline   Reply With Quote
Old 01-11-2018, 02:24 PM   #11
mongocanfly
Re: Mongos 81 c30
thanks....
the ebay mounts also use the clamshells and keep the engine in stock location..so far no issues...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-11-2018, 02:26 PM   #12
mongocanfly
Re: Mongos 81 c30
couple of pics of the coverlay door panels and dash cover.....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-11-2018, 04:47 PM   #13
RotaryRocketeer
Re: Mongos 81 c30
Originally Posted by mongocanfly View Post
thanks....
Cool, I will have to take a closer look at them. The Holley units are on sale AND shiny though....
Headed to pick up my 6.0 in just a couple hours! It's going on a stand for a bit before I drop it in, but I'm getting close.
Old 01-12-2018, 05:12 AM   #14
mongocanfly
Re: Mongos 81 c30
shiny don't mean much when you can barely see them....haha....
mine were similar to these https://www.ebay.com/itm/LS1-Convers...Syxe&vxp=mtrut mine are made of steel and was about 20-25 bucks shipped.......several years ago....they were not name brand
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-07-2018, 05:07 PM   #15
coveboy
Re: Mongos 81 c30
That is a killer flatbed on that truck! How decent is your mileage while towing with that set up?
Also for a driveway paint job that you have done some great work. I helped my roommate paint his m3 after he got to know a guardrail on the track a little too well, and I quickly learned I am not a painter haha
coveboy is offline   Reply With Quote
Old 03-17-2018, 08:09 PM   #16
mongocanfly
Re: Mongos 81 c30
thanks coveboy!!....for comparison with the 350/sm465 I got around 5mpgs while towing and 9-10mpgs unloaded.....with the lq9/nv4500 I get around 10mpgs towing and 16+ unloaded....all with 4.10 gears...
a driveway paint job was a nobrainer for me...a bodyshop quoted me 7k...just to paint the cab....I grin every time I hear a rock fly up and hit metal..thinking how my 300 or so dollar paint job looks
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-19-2018, 10:23 AM   #17
coveboy
Re: Mongos 81 c30
I envy that 10/16 mpg haha, my DD only gets about 12 unloaded and it's killin me (Toyota Land Cruiser...AWD v8 puts a hurting on the wallet). I bet that 6.0 is great in that beast, though.
And daggum $7k?! With that you could just build an entire additional truck!
Old 03-19-2018, 10:45 AM   #18
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Mongos 81 c30
Truck looks good Greg. Where did you get the Coverlay dash cover and door panels?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-21-2018, 04:56 PM   #19
G-NUT
G-NUT's Avatar
Re: Mongos 81 c30
Ditto on the dash and door panels.
Also, where did you pickup the motor and trans?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 03-21-2018, 05:04 PM   #20
mongocanfly
Re: Mongos 81 c30
I ordered the coverlay stuff straight from them..http://coverlaymfg.com/
the engine I got from lightning rod speed shop outta Chattanooga...it is a stock pullout..great guy to deal with... ..
the trans I got from a place in florida...it was a fresh rebuild and dynoed trans.....but I won't deal with them anymore. ..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-22-2018, 12:04 PM   #21
GMC Guy
GMC Guy's Avatar
Re: Mongos 81 c30
Nice looking swap! Do you have a link to those coil covers?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 03-23-2018, 08:16 PM   #22
mongocanfly
Re: Mongos 81 c30
the only "link"to those is me....I made them....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-23-2018, 08:39 PM   #23
808_67C10
808_67C10's Avatar
Re: Mongos 81 c30
I LOVE red interior! Nice lookn truck!
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 03-24-2018, 01:55 AM   #24
GMC Guy
GMC Guy's Avatar
Re: Mongos 81 c30
Oh nice! You considering going into production?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-28-2018, 01:54 AM   #25
mongocanfly
Re: Mongos 81 c30
haha...you wouldn't believe how many people have asked me that...I just made em from some scrap aluminum I had laying around....
the guy I got my engine from put pics of it on his hatebook page and he called me and said he could have sold 50 sets the first week....
Mongo...aka Greg
RIP Dad
RIP Jesse
