#76 |
![]() Join Date: Sep 2016
Re: 62 Burb project in the making.
New rear brake shoes and cylinders. They needed it. Merry Christmas!
#77 |
60-66 Nut
Yes they were worn down a bit.
Merry Christmas!
#78 |
We got a bit of the loose ends tied up last night.
Replaced the water pump that was leaking a bit. New balencer as the 50 year old one was showing its age. "Lambda" O2 sensor to adjust the carb to 14.7 close 15 average after a fine tune of the idle screws. Got the new windshield rubber from Steele Rubber maybe next week we will get that replaced the other one is just not working out. Along with new felts. |
#79 |
60-66 Nut
It sounds like you are making some good progress. How has the Winter weather been over there?
#80 |
Global warming has done a job. now snow and only 3 days of freezing weather in the 20F But lots of rain.
#81 |
After fighting with the windshield rubber (Just wouldent work) replaced it with the Steele ruber one and 2 hours and the help of a couple friends its sitting perfect.
#82 |
60-66 Nut
That's good to hear.
#83 |
Little progress. My Buddy Just picked up the licence plates today! One step closer to getting on the road just need some nice weather.
#84 |
Just a picture before paint on the install of the windshield.
#85 |
Pulled the heater core as it was leaking. Got another on the way to my sister and send it to the radiator shop along with a new temp.control. Should take care of the leak.
#86 |
60-66 Nut
Did you find a new Ranco valve (temp control) somewhere?
#87 |
Yes I did found a NOS on ebay.
#88 |
I keep forgetting to take pictures.
Licence plate is on at least the rear. Installed the cheap tach. Front fenders are patched. Working on the GPS spedo. got the bracket made. Bought the lug nuts for the wheels ( still need to get the tires). Little bit at a time. Now we just need some nice weather and take it for the first real drive over here. |
#89 |
Nice looking project man! I had a set of those wheels on a truck years ago and 2 sets of caps worked out for me, one was just 4 of the stock rear enclosed caps that would have came on those (they bolt straight to wheel) but they are pretty long and stick out and say 4x4 right on them (which I painted over).The second set were a lower profile center cap from a early 90's chevy 2500 2wd 6 lug truck and they were type that the lug nuts had threads on outside and center cap fastened to the lugs themselves not the wheels. I do not have pics unfortunately due to computer crash years ago with most of my old pics.
#90 | |
Thanks for the kind words.
I found some repop plastic that are on the way. Just plain knock off caps. Slowley coming along. Quote:
#91 |
Pictures of the fender rep.
#92 |
Getting a bit of sound dampening in along with the doors.
#93 |
Went to a street racing event.
200 miles made it with out any problems what so ever. 14 mpg just crusing 60 on the freeway so not too bad. Need a different trans though with the fuel prices here. Time to save up for a T5. ![]() Last edited by sirJim; 04-29-2018 at 10:07 AM. |
#94 |
Free carpet put in to quiet it up a bit more.
#95 |
60-66 Nut
That's great to hear that you got your Burb out and driving.
#96 |
Finaly got the car port cleaned out enough to fit it in.
#97 |
New tires and the polished rims.
#98 |
Never Ending Projects
Nice. Looks good.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#99 |
Putting the Fire Bucket to work, moving my daughters bed to her new place.
#100 |
60-66 Nut
Yes the Suburbans are quite handy for moving things.
