Old 01-12-2018, 12:12 PM   #1
kyhillbilly
69 K10 Transmission Question
I am about to start a build on a 69 K10. This will be a daily driver. I would like swap out the old bulldog 4 speed transmission & transfer case for a 5 speed manual and transfer case. This will bolted to early model 350 sbc engine. Which 5 speed and transfer case should I be looking for? Thanks in advance.
kyhillbilly is offline   Reply With Quote
Old 01-12-2018, 10:02 PM   #2
B. W.
B. W.'s Avatar
Re: 69 K10 Transmission Question
A lot of guys run the NV4500 & keep the 205, do a search, should find some info on this forum.
B. W. is offline   Reply With Quote
Old 01-13-2018, 02:35 AM   #3
jeffahart
jeffahart's Avatar
My idea. Keep the "Bulldog" put on a 4" lift with 35" tires. I assume 4.10s. Run the hell out of it. Hypothetical... you throw a rod through the block. Get another 350.... and run the hell out of it. You save bucks. Your truck is setup from the factory to run/haul/tow.
The mussing's of a cheap lazy old bugger!
White K20
jeffahart is offline   Reply With Quote
Old 01-13-2018, 01:15 PM   #4
kyhillbilly
Thanks guys! I appreciate the feedback.
